1. Accessing Pabbly Connect to Build Your Automation
To start building your form-to-CRM pipeline, you need to access Pabbly Connect. Open a new tab and search for pabbly.com to reach the Pabbly Connect landing page.
If you’re a new user, click on ‘Sign Up for Free’ to create a free trial account. After signing in, navigate to the workflow builder within Pabbly Connect to begin your automation journey.
2. Setting Up the Trigger with Typeform
In this step, you will set up a trigger using Typeform in Pabbly Connect. Click on the ‘Add Trigger’ button and select Typeform as your form builder.
- Choose the event type for your trigger
- Click ‘Connect’ and then ‘Add a New Connection’
- Select ‘Connect with Typeform’
Ensure your Typeform account is logged in during this process. After connecting, authorize Pabbly Connect to access your Typeform data, ensuring your data is secure.
3. Testing the Trigger with a Sample Submission
Once the trigger is set up, it’s time to test it. Click on ‘Save and Send Test Request’ to initiate the test. You will see a response indicating ‘Waiting for Webhook Response’.
To capture the response, open your Typeform and submit a test entry. Fill in the required fields, such as:
- First Name: Test
- Last Name: User
- Email: [email protected]
After submitting the form, you should receive a response in Pabbly Connect confirming the data capture, indicating the trigger is functioning correctly.
4. Adding an Action to Integrate with Zoho CRM
Next, you will add an action to send the captured data to Zoho CRM using Pabbly Connect. Click on ‘Add Action’ and select Zoho CRM from the list of applications.
Choose the event ‘Create Contact’ and click ‘Connect’. You will need to provide your Zoho CRM domain. For example, if your domain is zoho.in, copy and paste it into the required field.
Authorize Pabbly Connect to access your Zoho CRM account, ensuring that all permissions are granted for seamless integration.
5. Mapping Data from Typeform to Zoho CRM
Now, it’s time to map the data from your Typeform submission to Zoho CRM fields. In Pabbly Connect, you will see options to enter details for the new contact.
Instead of entering data manually, utilize the mapping feature. Map the fields such as:
- Last Name
This dynamic mapping ensures that whenever a new response is received, the data will automatically populate in Zoho CRM, keeping your records up to date.
In this tutorial, we demonstrated how to build a form-to-CRM pipeline using Pabbly Connect. By integrating Typeform with Zoho CRM, you can automate data capture and streamline your workflow efficiently.
