1. Accessing Pabbly Chatflow for B2B Integration
To create a WhatsApp chatbot for your B2B business, start by accessing Pabbly Chatflow. This platform allows you to design and manage your chatbot seamlessly.
Once you’re in Pabbly Chatflow, you will see various buttons on the left side. The first step is to name your flow. This is crucial for identifying your chatbot later. After naming it, you can begin designing your chatbot’s workflow.
2. Setting Up Trigger Events in Pabbly Chatflow
In this section, you will set up the trigger events that will activate your chatbot. Within Pabbly Chatflow, click on the trigger event option. You will see multiple types of trigger events to choose from.
  • Select “Keyword” as your trigger event.
  • Enter keywords like “Hello” and “Hi” that customers may use to engage.
  • Press the “Enter” button to save your keywords.
Now, whenever a customer sends any of these keywords to your WhatsApp business account, the chatbot will automatically respond with a welcome message.
3. Creating Welcome Messages in Pabbly Chatflow
Once the trigger event is set, the next step is to create a welcome message. In Pabbly Chatflow, you will need to add a message note. This note will include the welcome greeting for your customers.
  • Add a title for the message, such as “Welcome to Cyber Shield Security!”
  • Include an introductory message inviting them to explore services.
  • You can also create a list of options for customers to choose from.
After setting up the welcome message, connect it to the trigger node. This ensures that when a customer engages with the chatbot, they receive your crafted message immediately.
4. Linking Options and Services in Pabbly Chatflow
In this section, you will link various service options that customers can choose from. Using Pabbly Chatflow, you will create a list of services that will appear when a customer interacts with the bot.
  • Add service options like “Security Audit,” “Threat Monitoring,” and “Compliance.”
  • Connect each option to its corresponding service details.
  • Ensure each service option is linked back to the main flow for seamless navigation.
This setup allows customers to select the service they are interested in, and the chatbot will respond with relevant information about that service.
5. Finalizing and Testing Your Chatbot in Pabbly Chatflow
After creating the flow and linking all options, it’s time to finalize your chatbot. In Pabbly Chatflow, click the “Save” button to ensure all your settings are stored correctly.
Once saved, it’s crucial to test your chatbot. Engage with it using the keywords you set up earlier. Check if the welcome message appears and if the service options are functioning as intended. This step ensures your chatbot is ready for real customer interactions.
This tutorial has guided you through creating a WhatsApp chatbot for your B2B business using Pabbly Chatflow. By following these steps, you can automate customer interactions effectively, ensuring timely responses and improved service delivery.
