To start integrating Pabbly Chatbot with YouTube, you need to access Pabbly Connect. This platform serves as the central hub for all your integrations, allowing seamless communication between various applications.
Log into your Pabbly Connect account and navigate to the dashboard. From there, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the integration process.
2. Creating a Broadcast in Pabbly Chatbot
Once you are in Pabbly Connect, the next step is to create a broadcast in Pabbly Chatbot. This feature allows you to send promotional messages directly to your contacts via WhatsApp.
To create a new broadcast, click on the ‘Add Broadcast’ button. You will be prompted to choose the type of broadcast. Select ‘Broadcast Campaign’ and enter a name for your broadcast. You can then choose your audience, which can either be from an existing contact list or by uploading a CSV file.
  • Select existing contact list or upload a CSV file.
  • Choose the type of message: approved template or regular message.
  • Add any images or additional content as needed.
After setting up your audience, you can proceed to customize your message content. This flexibility allows you to tailor your communication based on your specific audience needs.
3. Uploading CSV Files in Pabbly Connect
In this section, we will focus on how to upload a CSV file using Pabbly Connect. This is crucial for sending messages to a larger audience efficiently.
When you select the option to upload a CSV file, ensure that your file is properly formatted. You can create this CSV using Google Sheets or Excel, ensuring it contains the necessary contact details. The maximum file size is 50 MB, and you can include up to 200,000 contacts.
  • Ensure your CSV file is formatted correctly with all necessary columns.
  • Upload the file directly in the Pabbly Connect interface.
  • Confirm successful upload before proceeding to the next step.
Once uploaded, you can easily select your contacts for the broadcast, ensuring that your messages reach the intended audience effectively.
4. Scheduling Broadcasts in Pabbly Chatbot
Scheduling your broadcasts is a key feature of Pabbly Connect. This allows you to send messages at the optimal time for your audience.
To schedule a broadcast, select the desired date and time from the scheduling options. You can set it for any future date, ensuring that your messages are sent when your audience is most likely to engage.
Additionally, you can enable the automatic retry feature for contacts that may not receive the message initially. This ensures that your important updates are not missed by any of your contacts.
5. Testing and Launching Your Broadcast
Before launching your broadcast, it’s essential to test it using Pabbly Connect. This ensures that everything works as intended and that your messages are received correctly.
To test your broadcast, enter a test contact number and click on the ‘Send Test Message’ button. Verify that the test message is received on your WhatsApp. Once confirmed, you can proceed to launch the full broadcast.
After launching, you can monitor the statistics of your broadcast through Pabbly Connect. This allows you to track engagement and effectiveness, ensuring that your campaigns are successful.
In this tutorial, we explored how to effectively use Pabbly Connect to integrate Pabbly Chatbot with YouTube and manage broadcasts seamlessly. By utilizing these tools, you can enhance your communication and outreach efforts significantly.
