1. Accessing Pabbly Chatflow for Your AI Assistant
To create an AI-powered admission assistant, first, access Pabbly Chatflow by visiting the Pabbly website. Sign up for a free account to explore its features and receive 100 free credits each month.
Once registered, navigate to the Pabbly Chatflow dashboard. This is where you will create and manage your AI assistant. Make sure to familiarize yourself with the platform’s layout to enhance your experience.
2. Setting Up WhatsApp Integration in Pabbly Chatflow
The next step involves integrating your WhatsApp number with Pabbly Chatflow. This integration is essential for your AI assistant to communicate with students.
- Click on the “Add WhatsApp Number” option on the dashboard.
- Follow the prompts to link your WhatsApp account.
- Ensure your WhatsApp account is verified for successful integration.
After completing these steps, your WhatsApp account will be successfully integrated with Pabbly Chatflow, allowing the AI assistant to function effectively.
3. Creating Your AI Assistant in Pabbly Chatflow
Once your WhatsApp number is linked, the next step is to create your AI assistant using Pabbly Chatflow. Begin by selecting the “AI Assistant” feature from the left sidebar of the dashboard.
Click on the “Add Assistant” button, provide a descriptive name, and select the instruction type. Choose the AI agent option to set up your assistant’s behavior. Customize its instructions to ensure it answers queries accurately based on university data.
- Set the temperature for responses—0.5 for balanced creativity.
- Select OpenAI as the model provider and choose GPT-4 Omni.
- Paste your OpenAI API key to enable AI functionalities.
With these settings, your AI assistant is now set up to handle student inquiries effectively through Pabbly Chatflow.
4. Uploading Knowledge Base for Accurate Responses
The knowledge base is crucial for your AI assistant to provide accurate information. In Pabbly Chatflow, upload a knowledge base file containing all relevant university information.
Create this file using Google Docs or any text editor, ensuring it covers admission processes, available courses, and eligibility criteria. Once the file is ready, upload it in the knowledge source section of Pabbly Chatflow.
- Ensure the file is in .txt or .pdf format.
- Limit the PDF size to under 90 MB for optimal performance.
- Upload the file and confirm it is correctly inserted.
With the knowledge base uploaded, your AI assistant can now provide precise answers to student queries using Pabbly Chatflow.
5. Finalizing Your AI Assistant in Pabbly Chatflow
After setting up the knowledge base, configure the assistant’s interface within Pabbly Chatflow. Customize the header and footer messages to reflect your university’s branding.
Enable the assistant’s active status and save your settings. This final step ensures that your AI assistant is ready to interact with students on WhatsApp, providing them with instant responses.
Once everything is set, you can also embed this AI assistant into your university’s website. By copying and pasting the provided code into your website’s HTML, your assistant will be accessible to visitors.
Creating an AI-powered WhatsApp assistant using Pabbly Chatflow streamlines the admission process by instantly answering student queries. This setup enhances communication and efficiency for universities, making it an invaluable tool.
