1. Getting Started with Pabbly Connect for HubSpot Integration
To initiate the integration process, first access Pabbly Connect. This platform allows you to connect various applications effortlessly. Start by logging into your Pabbly Connect account, which serves as the central hub for your integrations.
Once logged in, you will see the dashboard. Here, you can create new workflows to integrate HubSpot with other applications. Click on “Create Workflow” to begin setting up your integration.
2. Setting Up the HubSpot Trigger in Pabbly Connect
In this section, we will configure the HubSpot trigger using Pabbly Connect. Choose HubSpot as your trigger application. You will see various trigger events available, including “New Contact Created” and “New Company Created”.
  • Select “New Contact Created” to capture new contacts instantly.
  • Click the “Connect” button to establish a connection with your HubSpot account.
  • Choose your HubSpot account from the list.
After establishing the connection, select the response format as “Simple Response”. Click on “Save and Send Test Request” to verify the connection. This step ensures that Pabbly Connect can receive data from HubSpot.
3. Creating a New Contact in HubSpot
With the trigger set, the next step involves creating a new contact in HubSpot. Go to the HubSpot dashboard and navigate to the “Contacts” section. Click on the “Add Contact” button to start adding a new contact.
Fill in the contact details such as name, email, and phone number. Once you create the contact, Pabbly Connect will automatically capture the response. You will see the contact ID and other details reflected in the Pabbly dashboard shortly after.
  • Ensure you note the contact ID for verification.
  • Check for other captured details like email and phone number.
  • Confirm that the data appears in the Pabbly Connect response.
This process illustrates how Pabbly Connect instantly captures new contact data from HubSpot, allowing for seamless automation.
4. Integrating Additional Triggers and Actions in Pabbly Connect
Next, we will explore how to integrate more triggers using Pabbly Connect. For instance, if you want to capture when a new company is created, select the “New Company Created” trigger in the same way as before.
Follow the same connection steps as outlined previously. After confirming the connection, click on “Save and Send Test Request” to ensure that the new company data is captured as well. This allows you to harness multiple data points from HubSpot.
  • Select the appropriate company details to capture.
  • Verify that the company ID and other details appear in the response.
  • Utilize this data for further actions in your workflow.
By leveraging Pabbly Connect, you can create a comprehensive integration that captures various HubSpot events, enhancing your automation capabilities.
5. Using Captured Data for Automation with Pabbly Connect
Finally, we will discuss how to utilize the captured data from HubSpot in further actions within Pabbly Connect. For example, you can send a WhatsApp message to the newly created contact. To do this, add an action step after the trigger.
Select WhatsApp Cloud API as your action application. Configure the action by entering the required details such as the recipient’s phone number and the message content. This step showcases how Pabbly Connect can facilitate communication directly based on captured data.
  • Map the phone number from the trigger response to send the message.
  • Customize the message to include the contact’s name.
  • Click on “Save and Send Test Request” to verify message delivery.
This demonstrates the power of Pabbly Connect in automating communication workflows based on real-time data from HubSpot.
In this tutorial, we explored how to integrate HubSpot with Pabbly Connect using various triggers and actions. By leveraging this powerful integration, you can automate processes and enhance your business efficiency.
