1. Setting Up Pabbly Connect for WhatsApp Message Delays
To begin using Pabbly Connect for delaying WhatsApp messages, first, access your Pabbly Connect account. Pabbly Connect serves as the central integration platform that facilitates automation between various applications, including Pabbly Chatbot and WhatsApp.
Once logged in, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button to initiate the setup process. This is where you will define how to manage delayed messages using the delay node.
2. Creating a Pabbly Chatbot Flow for Order Cancellation
In this section, we will create a chatbot flow within Pabbly Chatbot to handle order cancellations. Pabbly Connect will ensure that the flow is triggered appropriately when a customer cancels an order.
Start by selecting the option to create a new flow. Here are the steps to set it up:
- Choose a trigger event for the cancellation.
- Add a message block to confirm the cancellation.
- Link the message block to the trigger.
After these steps, your chatbot will confirm the cancellation immediately upon customer action, showcasing the power of Pabbly Connect in automating customer interactions.
3. Implementing the Delay Node in Pabbly Chatbot
To send a follow-up WhatsApp message after a specific delay, you need to implement the delay node within your chatbot flow. Pabbly Connect allows you to set this up seamlessly.
Here’s how to add the delay node:
- Remove any previous connections that are not needed.
- Add the delay node to your flow.
- Set the delay type to “Delay for” and specify the duration.
Once you configure the delay node to wait for two hours (or your desired time), it will automatically trigger the next action in your flow.
4. Sending WhatsApp Messages After Delay
After setting up the delay node, the next step is to configure the action that sends the WhatsApp message. Pabbly Connect will handle this integration to ensure timely communication with your customers.
To send the WhatsApp message:
- Select the action event for sending a WhatsApp message.
- Input the message content that includes special offers or follow-up information.
- Connect this action to the delay node.
With these configurations, your customers will receive a follow-up WhatsApp message precisely after the specified delay, enhancing customer engagement through Pabbly Connect.
5. Testing Your Pabbly Connect Setup
Now that you have configured the delay and WhatsApp message, it’s time to test your setup. Pabbly Connect allows you to simulate the entire process, ensuring everything works as expected.
To perform the test:
- Trigger the cancellation event in your chatbot.
- Wait for the specified delay duration.
- Check if the follow-up WhatsApp message is received.
This testing phase is crucial to ensure that Pabbly Connect integrates all components correctly and that your customers receive timely communication.
In this guide, we explored how to use Pabbly Connect to delay WhatsApp messages effectively. By utilizing the delay node in Pabbly Chatbot, you can automate follow-up interactions and enhance customer engagement seamlessly.
