To automate WhatsApp reminders, start by accessing Pabbly Connect. Log in to your account and navigate to the Workflow Builder. This is where you will create the automation process.
Click on the “Add Trigger” button to begin. For the trigger application, select Google Sheets, and for the event, choose “New or updated spreadsheet row”. After clicking “Connect”, you will receive a Webhook URL.
2. Configuring Google Sheets with Pabbly Connect
Once you have the Webhook URL from Pabbly Connect, open your Google Sheet. Go to “Extensions”, then “Add-ons”, and select “Get add-ons”. Search for “Pabbly Connect Webhooks” and install it.
- Install Pabbly Connect Webhooks from Google Sheets Add-ons.
- Go back to your Google Sheet and refresh it.
- Navigate to “Extensions” > “Pabbly Connect Webhooks” > “Initial Setup”.
In the Initial Setup, paste the Webhook URL you copied earlier. Specify the trigger column, which in this case is column C for the participant details. Click “Submit” to save the settings.
3. Adding Delay and Sending Reminders
Next, return to Pabbly Connect and add a delay action. Select “Delay Until” and input the date for the first reminder, which is October 10th. Ensure you format the date in UTC.
After setting the delay, add a new action to send a WhatsApp message using Pabbly Chatbot. For this, select “Send Text Message” and connect your Pabbly Chatbot account. You will need to enter your API token found in the Pabbly Chatbot settings.
- Input your WhatsApp API token from Pabbly Chatbot.
- Map the recipient’s phone number from your Google Sheet.
- Compose your message, including dynamic fields like participant name.
Click “Save and Send Test Request” to confirm that the message is sent successfully to the recipient.
4. Repeating the Reminder Process for Multiple Notifications
To send additional reminders, copy the delay and WhatsApp message steps you created earlier. Change the delay to two days for the second reminder, and update the message content accordingly.
Repeat this process for the third reminder, adjusting the delay and message details as necessary. Ensure all messages are formatted correctly and include any dynamic data needed from your Google Sheet.
Finalize your workflow by testing each step. Make sure that each reminder is sent at the correct time and contains the right information for each participant.
5. Finalizing Your Automation with Pabbly Connect
After setting up all reminders, go back to your Google Sheet and ensure that the Pabbly Connect Webhooks are triggered by new entries. This will automate the process of sending reminders whenever a new participant registers.
Remember to test your entire workflow to verify that the reminders are sent as expected. Adjust any settings in Pabbly Connect if necessary to ensure smooth operation.
With this setup, you can easily manage event reminders and improve attendance rates with automated notifications through WhatsApp.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp reminders for your events. By integrating Google Sheets and Pabbly Chatbot, you can enhance your event management and ensure better participant engagement.
