To start integrating Now, API, WhatsApp, and OpenAI API, first access Pabbly Connect. This platform allows you to automate workflows seamlessly. Go to the Pabbly Connect website and create an account or log in.
Once logged in, you will see the dashboard. Here, you can create a new workflow by selecting the ‘Create Workflow’ button. This will be the foundation for connecting all your applications.
2. Setting Up WhatsApp Integration with Pabbly Connect
Now, let’s set up WhatsApp integration using Pabbly Connect. Begin by selecting WhatsApp as your trigger application. This will allow you to receive messages directly from your customers.
Follow these steps to configure WhatsApp:
- Select WhatsApp from the list of applications.
- Choose the event type, such as receiving a message.
- Connect your WhatsApp account by following the prompts.
After completing these steps, you will be able to receive messages from WhatsApp, which can then be processed by your AI assistant.
3. Configuring OpenAI API in Pabbly Connect
Next, we need to configure the OpenAI API to enable your AI assistant to respond to customer queries. This is done within Pabbly Connect by selecting OpenAI as the action application.
To set this up, follow these steps:
- Select OpenAI from the list of action applications.
- Choose the action event, such as sending a response.
- Input your OpenAI API key to authenticate.
With OpenAI configured, your AI assistant can now generate responses based on the messages received from WhatsApp.
4. Creating the AI Assistant with Pabbly Connect
Now, let’s create the AI assistant using Pabbly Connect. This assistant will pull information from your knowledge base to answer customer queries effectively. Start by navigating to the AI assistant section within the platform.
Follow these steps to create your assistant:
- Select the AI assistant option from the menu.
- Input necessary configurations such as temperature and model type.
- Upload your knowledge base document in TXT or PDF format.
Once your AI assistant is created, it will be ready to provide instant responses to customer inquiries based on the knowledge base you’ve provided.
5. Activating and Testing Your AI Assistant
Finally, it’s time to activate your AI assistant using Pabbly Connect and test its functionality. Ensure all settings are configured correctly to allow the assistant to operate smoothly.
To activate and test, follow these steps:
- Enable the assistant for your WhatsApp contacts in the settings.
- Send a test message from WhatsApp to see if the assistant responds.
- Make any necessary adjustments based on the test results.
After testing, your AI assistant will be fully operational, ready to assist your customers with their queries instantly.
In conclusion, using Pabbly Connect allows you to integrate Now, API, WhatsApp, and OpenAI API seamlessly. This setup automates customer interactions, providing instant responses and improving customer satisfaction. Start using Pabbly Connect today to enhance your business operations.
