To start integrating Instagram with LinkedIn, first access Pabbly Connect by visiting pably.com/connect in your browser. This platform allows users to automate workflows seamlessly between different applications.
Once on the landing page, click on the “Sign Up for Free” button located at the top right corner. You can begin with a free trial, allowing you to automate up to 100 Instagram posts to LinkedIn without any cost.
After signing up, navigate to your Pabbly Connect dashboard and click on the “Create Workflow” button. Here, you will initiate the automation process to connect Instagram and LinkedIn.
  • Type “Instagram to LinkedIn” in the workflow prompt.
  • Select “Instagram for Business” as your app.
  • Choose the event “New Media Posted in My Account”.
After selecting these options, click on the “Approve and Create” button. This sets up your workflow, allowing you to connect your Instagram and LinkedIn accounts through Pabbly Connect.
3. Connecting Instagram for Business
Next, you need to connect your Instagram account. Click on the “Connect” button next to Instagram for Business. Then, select “Add a New Connection” to link your account.
Ensure that your Instagram account is linked to Facebook, as this is required for the connection. Log in to your Instagram account when prompted, and click the “Continue” button once logged in. Your Instagram account will now be successfully connected to Pabbly Connect.
4. Setting Up LinkedIn Integration
Now, proceed to connect your LinkedIn account. Click on the “Connect” button next to LinkedIn and select “Add a New Connection”. Make sure you are logged into your LinkedIn account to avoid any issues during the connection process.
  • Once connected, refresh the fields if you don’t see any options.
  • Compose your LinkedIn post message, including a dynamic Instagram caption and link.
Using mapping, insert the caption and permalink from the previous Instagram step into your LinkedIn post. This ensures that every new Instagram post updates automatically on LinkedIn through Pabbly Connect.
5. Testing the Automation
After setting up your LinkedIn message, click on the “Send Test Request” button. This step confirms that your post will be shared successfully on LinkedIn. If successful, you will see a confirmation ID.
Now, refresh your LinkedIn account to see the new post appear. This confirms that your automation is working correctly, and every new Instagram post will now automatically share on LinkedIn, enhancing your engagement.
In this tutorial, we explored how to use Pabbly Connect to automate the sharing of Instagram posts to LinkedIn, maximizing your engagement across platforms. Try it out and streamline your social media efforts today!
