To start automating your Facebook and LinkedIn posts, first access Pabbly Connect by going to pabbly.com/connect in your browser. This is the central platform that simplifies integration between applications.
Once on the site, click on the “Sign Up for Free” button in the top right corner. After signing up, you will have access to a free trial of Pabbly Connect. If you find it beneficial, consider using the discount code RIT TYT for your subscription.
After logging into Pabbly Connect, navigate to the dashboard and click on “Create Workflow”. Use the quick builder to enter your workflow prompt, such as “Facebook post to LinkedIn”. This initiates the automation process.
- Select Facebook Pages as your trigger application.
- Choose “New Post” as the trigger event.
- For LinkedIn, select “Share Simple Text” as the action event.
Once you set these options, click on “Approve and Create” to finalize your workflow setup in Pabbly Connect.
3. Connecting Facebook and LinkedIn in Pabbly Connect
To connect your Facebook account, click on the “Connect” button in the workflow. Ensure that you are logged into your Facebook account, as Pabbly Connect will prompt you to do so if you aren’t.
After logging in, select the Facebook page you want to use. For this example, I chose “Digital Dynamics”. Keep the response format as simple and click on “Save and Send Test Request”. This action will capture the webhook response from your Facebook page.
4. Posting on LinkedIn Using Pabbly Connect
Once your Facebook post is created, switch to LinkedIn in your Pabbly Connect workflow. Click on the “Connect” button again, ensuring you are logged into your LinkedIn account. This will allow Pabbly Connect to share your Facebook content automatically.
- Map the content from Facebook to LinkedIn.
- Use the “Get Page Post Details” action to retrieve the Facebook post URL.
- Ensure the visibility setting is set to public or as per your preference.
After mapping the necessary fields, click on “Save and Send Test Request” to finalize the LinkedIn post. If successful, your Facebook content will now appear on LinkedIn.
5. Conclusion: Automate Your Social Media with Pabbly Connect
By following these steps, you can effortlessly automate sharing your Facebook posts on LinkedIn using Pabbly Connect. This integration not only saves time but also enhances your social media presence.
With Pabbly Connect, you can explore numerous other integrations and automate various tasks. Start using it today to streamline your social media management!
