To start using Pabbly Connect for automating your Facebook posts, first open your web browser and navigate to pabbl.com/connect. If you’re a new user, click on the “Sign up for free” option in the top right corner to create an account.
Once you have logged in, you will be directed to the workflow builder. This is where you will set up your automation. Make sure to explore the features available within Pabbly Connect to familiarize yourself with the interface.
In this section, we will set up the trigger for your automation using Pabbly Connect. Click on the “Add Trigger” button, and select “Scheduled by Pabbly” as your trigger application. For the event, choose “Schedule Workflow”.
  • Select how often you want the workflow to run (e.g., every day).
  • Set the time for the automation to trigger (e.g., 1:00 PM).
After configuring these settings, click on the “Save” button. Your workflow is now set to run daily at the specified time using Pabbly Connect.
3. Generating Content Using Gemini
Next, we will generate content for your Facebook post using Pabbly Connect and Gemini. Click on the “Add New Action Step” and search for “Gemini”. Select it and choose the event “Generate Content”.
If you haven’t connected Gemini to Pabbly Connect yet, you will need to create a new connection. This requires an API key from your Google AI Studio. Navigate to the “Get API Key” section, create your API key, copy it, and paste it into the connection settings in Pabbly Connect.
4. Creating Facebook Posts with Generated Content
Once content is generated, the next step is to post it on your Facebook page using Pabbly Connect. Click on “Add New Action Step” again, and search for “Facebook Pages”. Choose the event “Create Page Photo Post”.
Connect your Facebook account if you haven’t already. Make sure you select your Facebook page from the list. For the photo URL, map the response from Gemini where the image URL is located, and for the description, map the caption generated by Gemini.
  • Ensure the Facebook account is logged in to avoid connection issues.
  • Click on “Save and Send Test Request” to verify that the post is created successfully.
After successfully posting, refresh your Facebook page to see the new post with the caption and image generated by Gemini.
5. Conclusion: Automate Your Facebook Posts with Pabbly Connect
In this tutorial, we demonstrated how to use Pabbly Connect to automate daily Facebook posts by integrating it with Gemini. By following the steps outlined, you can efficiently generate content and schedule posts on your Facebook page.
With Pabbly Connect, automating your social media presence has never been easier. Start your free trial today and experience the benefits of streamlined content management for your Facebook page.
