1. Accessing Pabbly Connect to Send WhatsApp Messages
To start automating WhatsApp messages to Justdial leads, first access Pabbly Connect by visiting pabbly.com/connect. This is the central platform for managing your integrations seamlessly.
Once on the landing page, click on the “Sign Up for Free” button located in the top right corner. This will grant you a free trial of Pabbly Connect, allowing you to send up to 100 WhatsApp messages without any cost.
After logging into Pabbly Connect, navigate to your dashboard and click on “Create Workflow”. Here, you will set up the integration for sending WhatsApp messages to Justdial leads.
  • Name your workflow, e.g., “Send WhatsApp to Justdial Leads”.
  • Select the trigger as “New Leads” from Pabbly Chatflow.
  • Choose the action as “Send Text Message”.
Once these options are selected, click on “Approve and Create” to finalize your workflow setup in Pabbly Connect.
3. Setting Up Webhook for Justdial Integration
To connect Justdial with Pabbly Connect, you will need a webhook URL. This URL is crucial for automating lead capture from Justdial.
Copy the generated webhook URL from your workflow and click on “Recapture Webhook Response”. Provide this URL to your Justdial account manager, as the Justdial portal does not allow users to add webhook URLs directly.
Once the account manager integrates the webhook URL, you will start receiving lead details such as name, email, phone number, and area in Pabbly Connect. This will enable you to proceed with sending WhatsApp messages.
4. Connecting Pabbly Chatflow for WhatsApp Messaging
Now, it’s time to connect Pabbly Chatflow to send WhatsApp messages. Click on the “Connect” button in your workflow and then select “Add a New Connection”.
  • You will need an API token from your Pabbly Chatbot account.
  • Navigate to the settings in Pabbly Chatbot and find the API and Webhooks section.
  • Copy the API token and paste it into your Pabbly Connect workflow.
Once connected, enter the recipient’s WhatsApp number by mapping it from the previous response, ensuring that the data is dynamic and updates with each new lead.
5. Sending WhatsApp Messages Automatically
After setting up the recipient’s number, you can now write the WhatsApp message you want to send. You can either type a new message or copy an existing one from your previous workflows.
Before finalizing, ensure to clear any unnecessary fields and click on “Save and Send Test Request”. This will send a test message to confirm that everything is working correctly.
Once you receive a confirmation that the message was sent successfully, check your WhatsApp to see the automated message. This automation will ensure that every new lead from Justdial receives a timely WhatsApp message through Pabbly Connect.
In this tutorial, we explored how to automate WhatsApp messages to Justdial leads using Pabbly Connect and Pabbly Chatflow. By following these steps, you can streamline your communication with potential clients effectively.
