1. Setting Up Pabbly Chatflow for WhatsApp Integration
To start automating WhatsApp messages for new Facebook leads, first, access Pabbly Chatflow. This platform is essential for integrating WhatsApp with Facebook Lead Ads. If you are a new user, visit the Pabbly website and sign up for a free trial to explore its features.
Once logged in, navigate to the workflow builder of Pabbly Chatflow. This is where you will set up the automation process. You can send up to 100 WhatsApp messages for free, making it a great option to test before committing to a subscription.
To create a workflow, click on the “Add Trigger” button in Pabbly Chatflow. Select “Facebook Lead Ads” as the trigger event. This setup allows you to automate actions based on new leads generated from your Facebook ads.
  • Choose “New Lead” as the event.
  • Connect your Facebook account if you haven’t already.
  • Select the Facebook page and lead form you want to integrate.
After setting this up, click on “Save and Send Test Request” to ensure that the connection is working properly. This action will prepare your workflow to capture lead details automatically.
3. Testing the Facebook Lead Integration
To test the integration, use the Meta Lead Ads Testing Tool. This tool allows you to simulate lead submissions and check if Pabbly Chatflow captures the data correctly. Select the same page and lead form you configured earlier.
  • Fill out the form with test data (e.g., first name, last name, email).
  • Submit the form and observe if Pabbly Chatflow receives the data.
Once the test is successful, you will see the details captured in your workflow. This confirms that your integration between Facebook Lead Ads and Pabbly Chatflow is functioning as intended.
4. Sending WhatsApp Messages Using Pabbly Chatflow
Now that your lead data is captured, it’s time to send automated WhatsApp messages. In Pabbly Chatflow, click on “Send New Action Step” and choose “WhatsApp” as the application. This action will allow you to send messages directly to your leads.
For the event, select “Send Message” and connect your WhatsApp account. If you haven’t created a connection yet, you will need to input your API token from Pabbly Chatflow. Ensure your WhatsApp number is added to the platform before proceeding.
5. Mapping Lead Details in WhatsApp Messages
Mapping is a crucial step in personalizing your WhatsApp messages. In Pabbly Chatflow, you can dynamically insert lead details into your messages. For example, when composing your message, you can map the first name and last name from the previous step.
To map the details, simply click on the response field and select the appropriate data. This makes your messages more engaging and tailored to each lead. Here’s how to do it:
  • Insert the first name and last name using the mapping feature.
  • Format your message to include any special characters for emphasis, like stars for bold text.
After completing the message setup, click on “Save and Send Test Request” to verify that the message is sent successfully. You should see the message appear in your WhatsApp, confirming that the integration works flawlessly.
In this tutorial, we explored how to automate WhatsApp messages for new Facebook leads using Pabbly Chatflow and Pabbly Connect. By following these steps, you can efficiently engage with your leads, ensuring timely communication and improved conversion rates.
