To start integrating WhatsApp with Facebook leads, you first need to access Pabbly Connect. Simply open a new tab and type in pabyt.com/connect to reach the platform’s landing page.
If you’re a new user, you can sign up for free and receive 100 tasks to test the integration. After signing up, log in to your account, and you will be directed to the Pabbly Connect dashboard.
Once you’re on the dashboard of Pabbly Connect, it’s time to create a new workflow. Click on the “Create Workflow” button and select the option to create using AI.
  • Search for “Facebook leads to WhatsApp PBY Chatflow” in the prompt section.
  • Select “Facebook Lead Ads New Lead Instant” as the trigger event.
  • Choose “Pabi Chatflow” for the action event.
After selecting these options, approve and create the workflow. This setup will allow you to automatically send WhatsApp messages whenever a new Facebook lead is generated.
The next step involves connecting your Facebook Lead Ads to Pabbly Connect. Navigate to the connected option and click on “Add New Connection”. Then, click on the “Connect with Facebook Lead Ads” button.
Once you do this, you will be prompted to continue with your Facebook account. Choose the account that manages your Facebook lead ads and complete the connection process. Your page and form details will appear, allowing you to select the necessary options.
After setting up the connection, the next step is to send a WhatsApp message using Pabbly Connect. Select “Pabi Chatflow” and connect it by clicking on the “Add New Connection” option. You will need to provide an API token for this connection.
  • Navigate to the settings option in Pabi Chatflow and find the API and Webhook section.
  • Generate the token, copy it, and paste it into your Pabbly Connect workflow.
  • Map the recipient’s phone number and template name to send the message dynamically.
After mapping the necessary fields, click on the “Save and Send Test Request” button to test the setup. You should receive a confirmation message on WhatsApp, indicating that the integration is successful.
5. Conclusion
In this tutorial, we demonstrated how to integrate WhatsApp with Facebook leads using Pabbly Connect. This automation allows businesses to respond instantly to new leads, enhancing customer engagement and operational efficiency.
With the steps outlined, you can now set up your own automated notifications for leads generated through Facebook. This integration not only saves time but also ensures that your leads are promptly attended to, enhancing your business’s responsiveness.
