To begin using Pabbly Connect for WhatsApp messaging, first, navigate to pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage where you can sign up or log in.
If you are a new user, click on “Sign up for free” to create an account. Existing users can simply log in to access their dashboard. Once logged in, locate the Pabbly Chat Flow application and click on “Access Now” to enter your dashboard.
2. Setting Up Your WhatsApp Broadcast with Pabbly Connect
After logging into Pabbly Connect, you need to set up a WhatsApp broadcast. This involves using the broadcast feature within Pabbly Chat Flow to send bulk messages legally.
- Click on the “Broadcast” option in the left sidebar.
- Select “Add Broadcast” to create a new broadcast campaign.
- Choose the audience for your broadcast by uploading a CSV file or selecting an existing contact list.
Once your audience is selected, you can refine it by excluding any contacts you don’t want to message. This ensures that your broadcast reaches only the intended recipients.
3. Creating a Message Template for WhatsApp
Before sending messages, you need to create a message template in Pabbly Connect. This template will be used for your WhatsApp broadcast.
Go to the “Templates” section in Pabbly Chat Flow to create your message. You can draft your message and include any images or variables to personalize it. Ensure your template is approved by Meta to use it for broadcasting.
4. Sending and Testing Your WhatsApp Broadcast
Once your template is ready, return to the broadcast section in Pabbly Connect. Select your message template and proceed to test the broadcast by sending it to your own WhatsApp number.
- Enter your contact details and click “Send Test Message”.
- Check your WhatsApp for the received test message.
- If satisfied, proceed to schedule or send the broadcast immediately.
Testing ensures that your message appears correctly before sending it to your entire contact list. Once confirmed, you can choose to send it immediately or schedule it for a later date.
5. Monitoring Your Broadcast Performance
After sending your broadcast via Pabbly Connect, you can monitor its performance. This includes checking delivery stats such as sent, delivered, read, and failed messages.
In the broadcast section, you can also resend messages to any contacts that failed to receive them. This allows for effective follow-up and ensures that your communications reach your audience.
Using Pabbly Connect for WhatsApp broadcasts allows businesses to efficiently communicate with leads while ensuring compliance with messaging guidelines. By following the steps outlined, you can set up effective bulk messaging campaigns.
