To start using Pabbly Connect for WhatsApp integration, first, visit the Pabbly website. Open your browser and type in the URL: pabbly.com. This will direct you to the Pabbly homepage where you can find various tools, including Pabbly Connect.
Once on the homepage, locate the Pabbly Connect option. Click on it to access the dashboard. If you are a new user, you will need to sign up for an account. Existing users can log in directly. After logging in, you will be ready to set up your WhatsApp integration.
2. Connecting WhatsApp to Pabbly Connect
The next step in using Pabbly Connect is to connect your WhatsApp account. In the dashboard, look for the “Add WhatsApp Number” option. Click on it to initiate the connection process.
- Click on “Add WhatsApp Number”.
- Follow the prompts to input your WhatsApp number.
- Confirm the number to complete the connection.
Once your WhatsApp number is connected, you can begin utilizing the features of Pabbly Connect for sending messages and managing contacts efficiently. Make sure to verify your number to ensure seamless integration.
3. Uploading Contacts in Pabbly Connect
Now that you have connected WhatsApp, the next step is to upload your contacts using Pabbly Connect. Navigate to the “Add Contacts” option in the dashboard. Click on it, and then select “Add Bulk Contacts”.
To upload contacts, you need a CSV file. If your contacts are in Google Sheets or Excel, download them as a CSV file. Once you have the CSV file ready:
- Go to the “Add Bulk Contacts” section in Pabbly Connect.
- Drag and drop your CSV file into the upload area.
- Click “Insert” to add contacts to your Pabbly Connect account.
Make sure that your CSV file includes relevant details such as names, phone numbers, and email addresses. After uploading, you can map these fields to ensure that the data is organized correctly within Pabbly Connect.
4. Creating Message Templates in Pabbly Connect
After uploading your contacts, the next step is to create message templates. Go to the “Add Template” section in Pabbly Connect. This feature allows you to design messages that can be sent to your contacts.
To create a template, select the type of template you wish to make. For example, if you want to create a promotional message, choose the marketing option. You will need to fill in details such as:
- Template Name
- Language
- Message Content
Once your template is created, you can use it in your broadcasts. This feature helps streamline your messaging process, allowing you to send consistent messages to all your contacts using Pabbly Connect.
5. Broadcasting Messages via Pabbly Connect
With your contacts and templates ready, you can now broadcast messages using Pabbly Connect. Navigate to the “Add Broadcast” section. Here, you will need to provide a name for your broadcast.
Select the contact list you created earlier and choose the template you want to use for the broadcast. If you want to exclude any specific contacts, you can do that in this section as well. Once everything is set, click on “Send Broadcast” to start sending your messages.
You can also test your broadcast by sending it to your own number first. This ensures that everything works correctly before sending it to your entire contact list. After sending, you can check the status of your broadcast to see how many messages were delivered and read.
This tutorial has shown you how to integrate WhatsApp with Pabbly Connect for unlimited messaging. By following these steps, you can efficiently manage your contacts and send promotional messages to your customers effortlessly.
