To start using Pabbly Chatflow, navigate to pabbl.com/chartflow in your browser. If you are a new user, you can sign up for free and receive 100 credits to send WhatsApp messages.
Existing users can directly log in to their dashboard. This initial setup is crucial as it allows you to explore the features of Pabbly Chatflow and begin integrating WhatsApp for your campaigns.
2. Adding Your WhatsApp Number in Pabbly Chatflow
After accessing Pabbly Chatflow, the next step is to add your WhatsApp number. This is essential for sending messages through the platform. Navigate to the settings and locate the option to input your WhatsApp number.
  • Go to the settings section of Pabbly Chatflow.
  • Find the WhatsApp integration option.
  • Enter your WhatsApp number and save changes.
Once your WhatsApp number is added, you can proceed to create your broadcast campaign using Pabbly Chatflow.
3. Creating a Broadcast Campaign in Pabbly Chatflow
To create a broadcast campaign, go to the broadcast feature on the left side of the Pabbly Chatflow dashboard. Click on the “Add Broadcast” button to start the process.
Here, you will need to select the type of broadcast campaign you want to create. For this example, choose “Broadcast Campaign” and name it something relevant, like “Price Drop Alerts”. You can customize the name based on your needs.
4. Setting Up a Contact List for Your Broadcast
Creating a contact list is a key step in your broadcast campaign using Pabbly Chatflow. Navigate to the contact section and click on “Create Contact List”. Here, you will enter the name for your list and set the opted-in status.
  • Enter a unique name for your contact list.
  • Define the opted-in and incoming status for your contacts.
  • Select conditions for your contact list.
After creating your list, you can add contacts to it. This will allow you to send targeted messages through Pabbly Chatflow effectively.
5. Sending Price Drop Alerts via Pabbly Chatflow
Now that your broadcast campaign and contact list are set up, it’s time to send out your price drop alerts. In the broadcast settings, you can choose to send the message immediately or schedule it for later.
If you opt to send it now, simply click on “Send Instantly”. Alternatively, if you want to schedule it, select “Schedule for Later” and set your desired date and time. This feature in Pabbly Chatflow allows you to manage your campaigns effectively.
Once sent, you can track the performance of your broadcast. Go to the “View Stats” option to see metrics like sent, delivered, read, and failed messages. This insight helps you refine future campaigns using Pabbly Chatflow.
Using Pabbly Chatflow for WhatsApp integrations allows you to send effective price drop alerts to your customers. This step-by-step guide helps you automate your communication seamlessly.
