1. Accessing Pabbly Connect to Start Integration
To begin integrating Pabbly, Pab, and Facebook, you first need to access Pabbly Connect. Open your browser and navigate to pabli.com. Here, you will see options to either sign in or sign up for a free account.
If you are a new user, click on the “Sign Up Free” button to create your account. Existing users can simply log in. This step is crucial as Pabbly Connect is the platform that will facilitate the integration process.
After logging into Pabbly Connect, you will be directed to the dashboard. To create a new workflow, click on “Access Now” under the Pabbly Connect option. You will see two methods to create workflows: “Create from Scratch” and “Create using AI”.
  • Select “Create using AI” for a more guided experience.
  • Provide a brief description of your workflow.
  • Choose the trigger as “New Lead from Facebook”.
Once you’ve set the trigger, you will be prompted to select the specific Facebook lead ad that will initiate this workflow. This is where Pabbly Connect starts to automate the process of capturing leads from Facebook.
3. Setting Up the Trigger for Facebook Leads
In this step, you will configure the trigger to capture new leads from Facebook. Click on “Connect with Facebook Lead Ads” to link your Facebook account. You will need to grant access to Pabbly Connect to read your Facebook data securely.
After connecting, select the Facebook page associated with your lead ads. Ensure you choose the correct lead generation form to capture the leads accurately. This step is essential as it defines what information will be sent to your CRM via Pabbly Connect.
4. Setting Up the Action to Store Leads in Pab
Now that the trigger is set, the next step is to configure the action that will store the leads in Pab. Select “Create Contact” in Pab as the action event. This will allow Pabbly Connect to add new leads into your Pab CRM automatically.
  • Map the lead data fields from Facebook to Pab.
  • Ensure all required fields like name, email, and phone number are included.
Once the mapping is complete, click on “Save and Send Test Request” to verify that the integration works correctly. If successful, your leads will now be stored in Pab, demonstrating the power of Pabbly Connect in automating your lead management process.
5. Summary and Conclusion of the Integration Process
In summary, you have successfully set up an automation process using Pabbly Connect to integrate Pabbly, Pab, and Facebook. This workflow captures new leads from Facebook and stores them in your Pab CRM, streamlining your lead management.
This integration not only saves time but also enhances your ability to follow up with potential customers. With Pabbly Connect, you can easily automate various tasks, ensuring you never miss an opportunity to engage with your leads.
In conclusion, integrating Pabbly, Pab, and Facebook using Pabbly Connect is an efficient way to manage your leads. By following these steps, you can ensure a seamless flow of information that enhances your business operations.
