1. Introduction to Pabbly Chatflow for WhatsApp Broadcasting
Pabbly Chatflow is an essential tool for automating WhatsApp messages, allowing you to send daily deals effortlessly. By utilizing this platform, you can reach hundreds or thousands of customers at once without manual effort.
With Pabbly Chatflow, you can streamline your marketing efforts, ensuring that your customers receive timely updates about your offers. This automation not only saves time but also enhances customer engagement, making your marketing strategy more effective.
2. Setting Up Pabbly Chatflow for Daily Deals
To start sending daily deals using Pabbly Chatflow, first log into your account. This platform allows you to create broadcasts that automate your messaging process. After logging in, navigate to the broadcast section to begin setting up your campaign.
  • Click on the “Add Broadcast” button.
  • Choose the type of campaign you want to create, selecting “Direct Broadcast”.
  • Enter a name for your broadcast, such as “Daily Deals”.
Once you have set up the initial parameters, you can proceed to select the contact list from which to send your messages. Pabbly Chatflow makes it easy to manage your contacts efficiently.
3. Importing Contacts into Pabbly Chatflow
Next, you need to import your customer contacts into Pabbly Chatflow. This is crucial for sending personalized messages. You can create a new contact list by uploading a CSV file containing your customer data directly from Google Sheets.
To convert your Google Sheets data into a CSV file, navigate to the file menu and select “Download”. Choose the CSV format to save your customer list. After downloading, return to Pabbly Chatflow and upload the CSV file by clicking on the “Add Contact” button.
  • Select “Bulk Contacts” to upload your CSV file.
  • After uploading, ensure to save your contact list.
Creating a contact list in Pabbly Chatflow allows you to send targeted messages efficiently, ensuring that your promotions reach the right audience.
4. Creating Message Templates in Pabbly Chatflow
Once your contacts are imported, the next step is to create engaging message templates. Pabbly Chatflow lets you customize messages that can include images, text, and dynamic variables to personalize each message.
To create a template, click on the “Add Template” button. You can choose to generate a template using AI or customize it manually. Ensure your template is visually appealing and contains all necessary information about the daily deals.
  • Select the type of message, such as text or image.
  • Include a call-to-action button to direct customers to your website.
Once your template is ready, you can test it to ensure it displays correctly before sending it out to your customers.
5. Scheduling Broadcasts in Pabbly Chatflow
After creating your message template, you can schedule your broadcasts using Pabbly Chatflow. This feature allows you to send messages at specific times, ensuring your customers receive updates when they are most likely to engage.
When scheduling, you can choose to send messages instantly or select a specific date and time. For example, you might set your broadcast for 2 PM on a particular day to align with your marketing strategy.
To finalize your broadcast, click on the “Add Broadcast” button. This will schedule your messages to be sent according to the parameters you’ve set. Pabbly Chatflow ensures that your broadcasts are sent seamlessly, enhancing your customer communication.
Using Pabbly Chatflow, you can efficiently send daily deals to your customers via WhatsApp. This automation saves time and increases engagement, allowing you to focus on growing your business. By following this guide, you can leverage Pabbly Chatflow for effective WhatsApp marketing.
