To send bulk WhatsApp messages, the first step involves accessing Pabbly Connect. Start by visiting the Pabbly website and logging into your account. If you are new, you can sign up for free to explore the features offered by Pabbly Connect.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find various applications available for integration. Click on the option to access Pabbly Chatflow, which is essential for sending WhatsApp messages. Ensure that your WhatsApp number is connected to Pabbly Chatflow to proceed with the integration.
2. Creating a WhatsApp Template in Pabbly Chatflow
Before sending messages, you need a pre-approved WhatsApp template. This template allows you to send personalized messages with attachments. In your Pabbly Chatflow account, create a new template by navigating to the template section.
  • Draft your message and attach any images you want to include.
  • Ensure that your template is approved by Meta for usage.
  • Once approved, you can use this template for your broadcasts.
After setting up your template, you are ready to move on to the broadcasting section. This setup is crucial for sending bulk messages effectively using Pabbly Connect.
3. Sending Bulk WhatsApp Messages Using Pabbly Connect
Now that you have your template ready, it’s time to send the bulk WhatsApp messages. In your Pabbly Chatflow dashboard, navigate to the broadcast section. Here, you can create a new broadcast by clicking on the ‘Add’ button.
In the broadcast window, select the broadcast type as ‘Broadcast Campaign’. Name your broadcast (e.g., “Message with Attachment”) and choose the contact list from which you want to send messages. You can upload contacts from a CSV file if you have them stored in Google Sheets.
  • Select the message type: pre-approved template or regular message.
  • If using a template, ensure to input your dynamic variables for personalization.
  • Upload any media you want to include in the message.
After setting everything up, you can test your broadcast by sending a test message to your own WhatsApp number. This ensures that everything appears as intended before sending it to your entire contact list through Pabbly Connect.
4. Scheduling Your WhatsApp Broadcast
Once you have tested your broadcast, the next step is to schedule it for sending. In the broadcast setup, you can choose to send the message instantly or schedule it for a later time. If you opt to schedule, make sure to select a future date and time.
After selecting the date and time, click on the ‘Add Broadcast’ button. This action will schedule your broadcast, and you can view the status of sent, delivered, and failed messages in the dashboard. This feature is incredibly useful for managing your campaigns efficiently.
With Pabbly Connect, you can easily track the performance of your broadcasts and make adjustments as necessary. This ensures that your communication remains effective and timely.
5. Reviewing Broadcast Results in Pabbly Connect
After your broadcast has been sent, it’s important to review the results. In your Pabbly Chatflow dashboard, you can view statistics for each broadcast. This includes data on sent, delivered, read, pending, and failed messages.
If there are any failed messages, you can resend them easily through the dashboard. This feature allows you to ensure that all your intended recipients receive your messages without hassle. Pabbly Connect provides a seamless experience for managing these communications.
By leveraging Pabbly Connect, you can automate and optimize your WhatsApp messaging campaigns effectively. This not only saves time but also enhances your outreach capabilities significantly.
In this tutorial, we explored how to send bulk WhatsApp messages using Pabbly Connect. From setting up your account to scheduling broadcasts, each step was designed to streamline your communication process. By utilizing Pabbly Connect, you can enhance your messaging efficiency and ensure your campaigns are successful.
