To start using Pabbly Chatflow for bulk WhatsApp messaging, first, navigate to the Pabbly Chatflow dashboard. If you’re a new user, visit pabbl.com/chartflow to create an account. Click on “Sign up for free” in the top right corner to receive free credits for your initial use.
Once logged in, you can explore the features of Pabbly Chatflow. This tool allows you to send bulk WhatsApp messages effortlessly. After trying the free credits, consider subscribing to a plan that suits your business needs.
2. Adding Your WhatsApp Number in Pabbly Chatflow
Before sending messages, you must add your WhatsApp number in Pabbly Chatflow. Go to the dashboard and locate the section to input your WhatsApp number. If you’re unsure how to do this, tutorials are available in the description box below the dashboard.
After adding your number, proceed to the broadcast section by selecting it from the left sidebar. Here’s how to set up your broadcast:
  • Click on the “Add Broadcast” button.
  • Choose “Broadcast Campaign” as the type.
  • Name your broadcast (e.g., “New Launch”).
Now, select the contact list to whom you want to send messages. If you haven’t created a contact list yet, do so by accessing the contact section from the left sidebar.
3. Creating a Contact List in Pabbly Chatflow
To effectively use Pabbly Chatflow, creating a contact list is essential. Go to the contact section and choose to add either a single contact or bulk contacts. For bulk uploads, prepare a CSV file with customer details and upload it directly.
Follow these steps to create your contact list:
  • Click on “Add Bulk Contacts” to upload your CSV file.
  • Ensure your CSV file includes all necessary customer details.
  • Select the created contact list for your broadcast.
Once your contact list is ready, you can refine your audience by excluding specific contacts if necessary. This step helps in targeting the right customers for your messages.
4. Sending Broadcast Messages Using Pabbly Chatflow
With your contact list set up, you can now send broadcast messages via Pabbly Chatflow. Choose the message type, either a pre-approved template or a regular message. If using a template, ensure it has been created and approved by Meta.
Here’s how to proceed:
  • Select the message type and enter the required details.
  • For dynamic fields, use the format $name to personalize messages.
  • Test your message by entering a username and phone number before sending it out.
After testing, you can either send the broadcast instantly or schedule it for later. To schedule, select the date and time using the calendar button and confirm your broadcast setup.
5. Monitoring Broadcast Results in Pabbly Chatflow
After sending your messages through Pabbly Chatflow, it’s essential to monitor their performance. You can view stats like how many messages were sent, delivered, read, pending, or failed. This data helps you understand the effectiveness of your messaging strategy.
To check your broadcast results:
  • Access the broadcast section to view detailed statistics.
  • Analyze the delivery rates and engagement levels of your messages.
  • Adjust future messaging strategies based on these insights.
Utilizing Pabbly Chatflow not only streamlines your communication but also enhances your marketing efforts through effective messaging campaigns.
In summary, using Pabbly Chatflow for bulk WhatsApp messaging simplifies the process of reaching your customers. By following the steps outlined, you can effectively communicate product launches and updates. Start leveraging Pabbly Chatflow today for efficient marketing solutions!
