To start using Pabbly Chatflow, open a new tab in your browser and navigate to pabbl.com/chartflow. This platform is essential for managing your WhatsApp messaging campaigns effectively.
Once on the landing page, you can sign up for a free trial. This allows you to send up to 100 WhatsApp messages without charge, giving you a risk-free way to explore its features.
2. Setting Up Your WhatsApp Number in Pabbly Chatflow
After signing up, log into your Pabbly Chatflow dashboard. The first step is to add your WhatsApp number. This is crucial as it will be the number you use to send messages.
To add your WhatsApp number, follow these steps:
- Navigate to the settings section of Pabbly Chatflow.
- Enter your WhatsApp number in the designated field.
- Save your changes to ensure your number is added.
Make sure to verify your number to avoid any issues when sending messages.
3. Creating a Broadcast Message with Pabbly Chatflow
To send bulk WhatsApp messages, go to the broadcast section in Pabbly Chatflow. Click on the “Add Broadcast” button to create a new campaign.
Here’s how to set up your broadcast:
- Choose a broadcast type and name your broadcast campaign.
- Select your audience by choosing an existing contact list or uploading a CSV file.
- Exclude any specific contacts or lists if necessary.
This setup ensures that your messages reach the right audience without causing complaints or issues.
4. Crafting Your Message in Pabbly Chatflow
Now that your broadcast is set up, it’s time to craft your message. You can either use a pre-approved template or create a custom message in Pabbly Chatflow.
To create your message, follow these steps:
- Enter your message in the provided text box.
- Use dynamic values like “${name}” to personalize messages for each recipient.
- Test your message by sending a test WhatsApp to your number.
By personalizing your messages, you enhance engagement and reduce the chances of your messages being ignored or reported.
5. Scheduling and Sending Your Broadcast via Pabbly Chatflow
Once your message is ready, you can schedule it for later or send it immediately through Pabbly Chatflow. This flexibility allows you to plan your marketing campaigns effectively.
To schedule your broadcast:
- Select the date and time for your broadcast from the calendar.
- Choose the option to automatically retry for failed contacts if desired.
- Click the “Add Broadcast” button to finalize your scheduling.
This ensures your messages are sent at optimal times and that any issues with delivery are handled automatically.
Using Pabbly Chatflow allows businesses to send bulk WhatsApp messages legally and efficiently. By following the steps outlined in this tutorial, you can effectively manage your WhatsApp marketing campaigns and enhance customer engagement.
