To send bulk WhatsApp messages, you first need to access Pabbly Connect. Open your browser and type in pabbl.com/chartflow to reach the Pabbly Chartflow landing page.
Once there, sign up for free to receive 100 credits each month. This allows you to explore the features of Pabbly Connect and send up to 100 WhatsApp messages for free. After testing, you can opt for a subscription plan if needed.
2. Setting Up Your WhatsApp Number in Pabbly Connect
Before sending messages, ensure your WhatsApp number is added to Pabbly Connect. This is crucial for the integration process.
If you need guidance on how to add your WhatsApp number, refer to the detailed video tutorial provided in the description box. This ensures you have everything set up correctly before proceeding.
3. Creating a Broadcast in Pabbly Connect
Next, navigate to the broadcast feature in Pabbly Connect. Here, you will see existing broadcasts, but you need to create a new one. Click on ‘Add Broadcast’ to start.
  • Select ‘Broadcast Campaign’ as the type.
  • Name your broadcast (e.g., ‘New Offer’).
  • Choose your contact list.
Once the broadcast is set up, you can select the message type. You can either choose a regular message or a pre-approved template message. Make sure to follow the steps accurately to ensure everything functions smoothly.
4. Sending Broadcast Messages via Pabbly Connect
After creating your broadcast, it’s time to send out your messages. Enter the username and mobile number for testing. Click on ‘Send Test Message’ to verify that everything is working correctly.
Once the test is successful, you can proceed to send the broadcast to multiple users. You have the option to send instantly or schedule for later. This flexibility allows you to manage your messaging effectively.
  • Choose ‘Send Instantly’ or ‘Schedule for Later’.
  • Select the date and time if scheduling.
After scheduling, you can check the stats of your broadcast, including sent, delivered, read, and failed messages. This feature provides valuable insights into your messaging campaigns.
5. Exploring More Features of Pabbly Connect
In addition to sending bulk messages, Pabbly Connect offers various other features. You can create templates and manage your contact list directly within the platform.
If you want to dive deeper into any specific feature like templates or contacts, check the additional video tutorials linked in the description. This will enhance your understanding and usage of Pabbly Connect.
In this tutorial, we explored how to send bulk WhatsApp messages using Pabbly Connect. By following these steps, you can efficiently manage your communication strategy and reach multiple clients with ease.
