To send bulk WhatsApp messages, you first need to access Pabbly Chatflow. Open a new tab and search for pabbly.com/chartflow in your browser. This will take you to the landing page of Pabbly Chatflow, which is powered by the official WhatsApp Business Cloud API, reducing the risk of your number getting blocked.
Once on the homepage, click on the ‘Sign Up for Free’ button to create an account. After signing up, you can explore the features of Pabbly Chatflow with a free trial. If you find it useful, consider purchasing a subscription plan for continued access.
2. Adding Your WhatsApp Number to Pabbly Chatflow
Before sending messages, ensure that you have added your WhatsApp number in Pabbly Chatflow. If you haven’t done this yet, refer to the tutorial linked in the description box below. Once you’ve added your number, navigate to the broadcast section on the left side of the dashboard.
  • Locate the ‘Broadcast’ section in Pabbly Chatflow.
  • Click on the ‘Add Broadcast’ button.
  • Select the broadcast type as ‘Broadcast Campaign’.
After clicking ‘Add Broadcast’, name your broadcast and select the contact list you wish to target. You can also choose to exclude certain contacts if necessary. This flexibility ensures that you can manage your audience effectively while using Pabbly Chatflow.
3. Creating Broadcast Messages in Pabbly Chatflow
With your broadcast set up, it’s time to create the message. In Pabbly Chatflow, you have two options for messaging: pre-approved template messages or regular messages. For this tutorial, we will use a regular message.
To create your message, select the message type as ‘Text’ and enter your desired text. You can format your message by adding stars around the text you want to bold. For instance, if you want to bold the word “Hello”, you would type it as *Hello* in the message box.
  • Enter your own name and WhatsApp number for testing.
  • Click on ‘Send Test Message’ to verify your message.
After confirming that your message looks good, you can either schedule it for later or send it instantly. This feature is one of the many advantages of using Pabbly Chatflow for your WhatsApp messaging needs.
4. Sending Your Broadcast Using Pabbly Chatflow
Once your message is ready, you can proceed to send it. In Pabbly Chatflow, you can choose to send your broadcast immediately or schedule it for a later time. To schedule, select your preferred date and time from the calendar.
Additionally, you can enable the option to automatically retry sending messages to failed contacts. This ensures that if a message fails to send to any of your contacts, Pabbly Chatflow will attempt to resend it based on your specified retry settings.
After configuring these options, click on the ‘Add’ button to finalize your broadcast. You can then view the stats of your broadcast, including how many messages were sent, delivered, read, or failed. This detailed feedback is crucial for optimizing your future messaging campaigns through Pabbly Chatflow.
5. Conclusion
In this tutorial, we covered how to effectively send bulk WhatsApp messages using Pabbly Chatflow. By following the steps outlined, you can leverage the power of Pabbly Chatflow to enhance your messaging capabilities and reach your audience efficiently.
Utilizing Pabbly Chatflow not only simplifies the process but also ensures that your messages are delivered without risking your number getting blocked. Start using Pabbly Chatflow today to transform your communication strategy!
