To start using Pabbly Connect for sending bulk WhatsApp messages, first, visit the Pabbly Chartflow homepage by searching for Pabbly Connect in your browser. You’ll find options to either sign in or sign up for free. If you’re new, click on “sign up free” to create an account.
Once you’re logged in, you’ll be directed to the Pabbly Chartflow dashboard. Here, you can connect your WhatsApp number, which is essential for sending messages. This integration allows you to manage your WhatsApp communications effectively.
2. Creating Broadcasts Using Pabbly Connect
After accessing your Pabbly Chartflow dashboard, navigate to the broadcast section. Click on the “add broadcast” button to initiate the process of creating a new broadcast campaign.
  • Choose the broadcast type as “broadcast campaign” from the dropdown menu.
  • Enter a name for your broadcast, such as “new broadcast”.
  • Select your contact list from existing options.
These steps are crucial for setting up your broadcast effectively. By using Pabbly Connect, you ensure that your messages reach the intended recipients without hassle.
3. Choosing Message Type in Pabbly Connect
Once you have set up your broadcast, the next step is to choose the message type. You can select either a pre-approved template message or a regular message. For this tutorial, we will use a pre-approved template.
To proceed, select the template you have created for your business. If you want to personalize the message, you can include variables in your template, making it more engaging for your recipients. This functionality is a significant advantage of using Pabbly Connect.
4. Testing and Scheduling Your Broadcast
Before sending your broadcast to all contacts, it’s essential to test the message. Enter your own phone number and click on “send test message”. This ensures the message appears as intended.
  • After testing, decide whether to send the broadcast instantly or schedule it for later.
  • If scheduling, select a future date and time.
Using Pabbly Connect for testing and scheduling ensures that your messages are sent at the right time, maximizing engagement with your audience.
5. Tracking Broadcast Results with Pabbly Connect
After your broadcast is sent, you can track its performance through Pabbly Connect. You will have access to statistics showing the number of messages sent, delivered, read, pending, ignored, and failed.
This data is invaluable for assessing the effectiveness of your campaign. If any messages failed to deliver, you can easily resend them using the options available in the dashboard, showcasing the efficiency of Pabbly Connect.
In this tutorial, we explored how to leverage Pabbly Connect to send personalized bulk WhatsApp messages effectively. By following the steps outlined, you can enhance your communication strategy and engage more effectively with your audience.
