1. Accessing Pabbly Connect for Sending Bulk Diwali Wishes
To send bulk Diwali wishes on WhatsApp automatically, you first need to access Pabbly Connect. Start by opening a new tab and searching for “Pabbly Chatflow” to find the landing page.
Once on the Pabbly Chatflow page, look for the “Sign up for Free” option at the top right corner. Click on it to create a free trial account, which allows you to send up to 100 WhatsApp messages for free.
2. Setting Up Your WhatsApp in Pabbly Connect
After signing up, log into your Pabbly account and navigate to the dashboard. Here, you need to add your WhatsApp number. This step is crucial for sending messages through Pabbly Connect.
  • Add your WhatsApp number in the designated field.
  • Follow the instructions if you need help adding your number.
  • Ensure your number is verified for sending messages.
Once your number is added, proceed to the left sidebar and click on “Broadcast”. You will then click on the “Add Broadcast” button to create a new broadcast campaign.
3. Creating a Broadcast Campaign in Pabbly Connect
In this step, you will create a broadcast campaign to send your Diwali wishes. Select “Broadcast Campaign” as the type and name it accordingly, such as “Diwali Wishes”. This name will help you identify your campaign later.
Next, you will be prompted to select your audience. You can either upload a CSV file with your contacts or choose from an existing contact list. If you upload a CSV file, make sure it contains all the necessary contact information.
  • Upload your CSV file with customer data.
  • If using an existing list, ensure it’s created beforehand.
  • You can exclude contacts if necessary.
After selecting your audience, you can refine your audience further by excluding any contacts that you do not wish to message. This feature ensures that your broadcast reaches only the intended recipients.
4. Composing Your Diwali Message in Pabbly Connect
Now it’s time to compose your message. You can choose to use a pre-approved WhatsApp template or create a regular message. If you opt for a template, ensure it has been approved by Meta.
For this tutorial, we will create a regular message. Enter your message in the designated field and use dynamic fields to personalize your greetings. For instance, you can include the recipient’s name by typing “${name}” to dynamically insert their name into the message.
Enhance your message by making certain text bold. To do this, add asterisks (*) around the text you want to emphasize. This formatting will make your message more visually appealing and engaging for the recipients.
5. Scheduling Your Broadcast in Pabbly Connect
Once your message is ready, you can either send it instantly or schedule it for later. If you choose to schedule, select the date and time when you want your broadcast to go out. This feature allows you to plan your Diwali wishes ahead of time.
Additionally, Pabbly Connect offers an option to automatically retry sending to failed contacts. You can set this feature to retry sending messages within a specified time frame, ensuring that your wishes reach as many recipients as possible.
Finally, click on the “Create Broadcast” button to finalize your setup. After the broadcast is created, you can check the statistics to see how many messages were sent, delivered, or failed. This tracking feature helps you gauge the success of your Diwali wishes campaign.
This tutorial demonstrated how to use Pabbly Connect to send bulk Diwali wishes on WhatsApp automatically. By following these steps, you can streamline your festive greetings efficiently and effectively.
