1. Introduction to Pabbly Connect for Travel Agencies
In this tutorial, we will explore how Pabbly Connect can help travel agencies automate their booking confirmations via WhatsApp. This automation saves time and enhances customer satisfaction.
Pabbly Connect is a powerful no-code platform that connects various applications seamlessly. By integrating Google Sheets with WhatsApp through Pabbly Connect, travel agencies can send personalized booking confirmations automatically.
2. Setting Up Google Sheets with Pabbly Connect
To begin, you need to access your Google Sheets where traveler details are maintained. Using Pabbly Connect, we will set up a webhook to capture new entries in the sheet.
Here are the steps to set up:
  • Open your Google Sheet and click on Extensions.
  • Select Add-ons, then Get add-ons.
  • Search for Pabbly Connect Webhooks and install it.
  • Click on Initial Setup and paste the webhook URL from Pabbly Connect.
After completing these steps, your Google Sheet will be connected to Pabbly Connect, allowing it to send data whenever a new booking is made.
3. Configuring Pabbly Chatbot Integration
Next, we will configure the Pabbly Chatbot within Pabbly Connect to send WhatsApp messages. This involves selecting the action application and establishing a connection.
Follow these steps to set up the integration:
  • In Pabbly Connect, select Pabbly Chatbot as the action application.
  • Click on Connect and then Add New Connection.
  • Enter the API token from your Pabbly Connect dashboard.
  • Map the recipient’s WhatsApp number and message content.
This setup allows Pabbly Connect to send personalized messages to travelers automatically, ensuring timely communication.
4. Testing the Integration
After configuring the integration, it’s essential to test it to ensure everything works as expected. Using Pabbly Connect, you can send test messages to verify the setup.
To test the integration, do the following:
  • Enter a new traveler record in your Google Sheet.
  • Click on Save and Send Test Request in Pabbly Connect.
  • Check the recipient’s WhatsApp for the confirmation message.
This testing phase confirms that Pabbly Connect is functioning correctly, automating the process as intended.
5. Real-Time Automation with Pabbly Connect
Once the integration is successfully tested, you can enjoy real-time automation. Every time a new booking is made in your Google Sheet, Pabbly Connect will automatically send a WhatsApp confirmation.
To see this in action, simply add a new entry with traveler details, and watch as the message is sent instantly. This feature significantly reduces manual effort and enhances efficiency.
With Pabbly Connect, travel agencies can ensure that every traveler receives their booking details promptly, improving overall service quality.
In summary, using Pabbly Connect to integrate Google Sheets with WhatsApp automates booking confirmations for travel agencies. This process saves time and enhances customer engagement, making it a valuable tool for any business.
