To start sending personalized WhatsApp messages, first, you need to access Pabbly Connect. This platform allows seamless integration between various applications, including Pabbly Chatbot and CSV files.
Once logged in, navigate to the Pabbly Connect dashboard. From here, you can set up your integration workflow that connects Pabbly Chatbot with your customer database in CSV format.
2. Setting Up the Broadcast Campaign in Pabbly Chatflow
Next, you’ll create a broadcast campaign using Pabbly Connect. Go to the “Broadcast” feature in Pabbly Chatflow. Click on the “Add Broadcast” button to initiate a new campaign.
- Choose the type of broadcast you want to create.
- Name your broadcast campaign, e.g., “Exclusive Skincare Offer”.
- Select the audience by choosing an existing contact list.
This setup allows you to target specific customers effectively. Ensure you have your contact list ready, which can be created or imported from a CSV file.
3. Uploading Your CSV File for Personalized Messaging
Now, let’s upload your CSV file using Pabbly Connect. This file should contain customer details such as first name, last name, and phone number.
To upload, click on the “Add New File” option and select your CSV file from your device. Ensure that your CSV file meets the following criteria:
- Maximum file size: 50 MB.
- Up to 200,000 contacts can be added.
With this setup, each customer will receive a personalized message, automatically including their name in the greeting.
4. Crafting Your Message Template in Pabbly Chatbot
After setting up your audience, you need to create a message template in Pabbly Connect. This template will be used for sending personalized messages.
Choose a pre-approved message template and include variables for personalization. For example, use “Hello {name}” where {name} will dynamically pull from your CSV list.
To add images or other media, select the appropriate options within the template settings. This enhances the visual appeal of your messages.
5. Testing and Scheduling Your Broadcast Campaign
Before launching your campaign, it’s crucial to test it. Use Pabbly Connect to send a test message to ensure everything works perfectly.
After successful testing, you can schedule your broadcast. Choose a date and time for the messages to be sent, or opt to send them immediately.
Utilizing the automatic retry feature can help in resending messages to contacts that may have failed to receive them initially. This ensures maximum outreach.
Using Pabbly Connect simplifies the process of sending personalized WhatsApp messages to your clients efficiently. By following the steps outlined, you can easily reach out to your audience with tailored messages that enhance customer engagement.
