1. Setting Up Pabbly Connect for WhatsApp Broadcasts
To create a WhatsApp broadcast campaign, you need to start by accessing Pabbly Connect. This platform allows you to integrate various applications seamlessly. First, sign in to your Pabbly account and navigate to the Pabbly Connect dashboard.
Once you’re logged in, ensure that you have your WhatsApp number added to Pabbly Connect. This step is crucial as it enables the platform to send messages on your behalf. If you haven’t added your WhatsApp number yet, refer to the instructions provided in the Pabbly documentation for guidance.
2. Creating Your Broadcast Campaign in Pabbly Connect
After setting up your account, the next step is to create your broadcast campaign using Pabbly Connect. Click on the “Add Broadcast” button to get started. You will be prompted to select the type of broadcast campaign you want to create.
  • Select the broadcast type as “Broadcast Campaign”.
  • Name your broadcast campaign, for example, “Special Offer”.
  • Choose the contact list to which you want to send the broadcast.
By following these steps in Pabbly Connect, you can efficiently manage your promotional messages. Make sure your contacts are organized into lists for easier targeting.
3. Adding Contacts for Your Broadcast Campaign
To effectively use Pabbly Connect, you need to add contacts to your account. This can be done manually or in bulk using a CSV file. Navigate to the “Contacts” section and click on the “Add Contacts” button.
  • You can upload a CSV file containing your contacts.
  • Ensure your CSV file includes columns for first name, last name, and phone number.
  • Pabbly Connect allows a maximum of 200,000 contacts in one upload.
Once your contacts are added, you can easily select them when creating your broadcast campaign. This ensures that your promotional messages reach the right audience.
4. Utilizing the Broadcast Feature of Pabbly Connect
The broadcast feature in Pabbly Connect is designed to simplify the process of sending messages to multiple contacts at once. After setting up your campaign and adding contacts, you can refine your audience by excluding specific contacts if necessary.
When you are ready to send your broadcast, choose the message type. You can opt for either a pre-approved template message or a regular message. For promotional broadcasts, it’s best to use a pre-approved template to ensure compliance with WhatsApp’s policies.
5. Scheduling Your Broadcast Campaign in Pabbly Connect
Once your message is ready, the final step in Pabbly Connect is to schedule your broadcast. You can select to send it instantly or schedule it for a later date and time. This flexibility allows you to optimize your campaign timing for maximum impact.
After scheduling, you can view the stats of your broadcast and even export reports to analyze the performance of your campaign. This feature is essential for understanding the effectiveness of your promotional efforts.
In conclusion, using Pabbly Connect for WhatsApp broadcast campaigns allows you to efficiently reach a large audience with your promotional messages. By following these steps, you can create impactful campaigns that drive engagement and sales.
