1. Accessing Pabbly Connect for LinkedIn Automation
To start posting daily on LinkedIn, access Pabbly Connect by opening a new tab and searching for pabbly.com/connect. This platform will facilitate the integration of various applications to streamline your posting process.
Once you reach the landing page of Pabbly Connect, click on the “Sign Up for Free” option located in the top right corner. This will allow you to create a free trial account, enabling you to explore the features of Pabbly Connect and create up to 100 posts for free.
After logging into your Pabbly Connect dashboard, the next step is to create a new workflow. Click on the “Create Workflow” button and choose the quick builder option. Name your workflow as “Daily LinkedIn Post” to keep it organized.
- Type “Daily LinkedIn Post” in the workflow name field.
- Select your AI agent, in this case, Gemini, to generate the content.
- Click “Send” to analyze your request.
Once the request is analyzed, select the trigger as “Schedule Workflow” and for the event, choose “Generate Content.” This setup is crucial for automating your LinkedIn posts using Pabbly Connect.
3. Scheduling Your LinkedIn Posts
To ensure your posts go live daily, you need to schedule them. In your workflow, open the schedule option and specify how often you want your posts to run. For instance, you can set it to run every day at 12:00 PM.
After selecting the date and time, click on the “Save” button. This action finalizes the scheduling, and your workflow is now set to generate and post content automatically. With Pabbly Connect, you can ensure that your LinkedIn presence remains active without manual intervention.
4. Connecting Gemini and LinkedIn through Pabbly Connect
Next, you will connect Gemini to generate the post content. Click on the connect option in Gemini and add a new connection. You will need to provide the API key, which you can obtain from Google AI Studio.
- Navigate to Google AI Studio and click on “Get API Key”.
- Create a new API key by naming it and selecting your project.
- Copy the generated key and paste it into your workflow in Pabbly Connect.
Once the connection is established, enter the prompt for your LinkedIn posts. This prompt can be customized for your business needs. Select the model of your choice, set the method to “Generate Content,” and click on the “Save and Send Test Request” button. This action will trigger the content generation process through Pabbly Connect.
5. Posting Content to LinkedIn
After generating the post content, the next step is to connect to LinkedIn. Click on the connect button within your workflow and log into your LinkedIn account when prompted. This is essential for Pabbly Connect to post content on your behalf.
Once logged in, select the author for your posts. If no options appear, refresh the fields. Then, map the generated content from Gemini to the content field in LinkedIn. This mapping ensures that each post is dynamic and updates with new content automatically.
Set the visibility to public and click the “Save and Send Test Request” button. If successful, you will receive a confirmation ID indicating that your post has been successfully shared on LinkedIn. This automation allows you to maintain a consistent posting schedule without manual effort, thanks to Pabbly Connect.
In summary, using Pabbly Connect to automate daily LinkedIn posts is efficient and straightforward. By integrating applications like Gemini and Google AI Studio, you can ensure a consistent online presence with minimal effort. Start automating your LinkedIn posts today for enhanced engagement!
