1. Accessing Pabbly Connect for Blog Automation
To start automating blog posting, first access Pabbly Connect by opening a new tab and searching for pabbli.com/connect. This will direct you to the Pabbly Connect landing page.
In the top right corner, you will see the option to sign up for free. Click on this button to create an account and begin your free trial of Pabbly Connect. You can generate up to 100 blogs for free during this trial period.
2. Setting Up Your Workflow in Pabbly Connect
Once logged into Pabbly Connect, you will arrive at the workflow builder. This is where you set up triggers and actions for your automation. Click on the “Add Trigger” button to begin.
  • Select the trigger application as “Schedule”.
  • Choose the event as “Schedule Workflow”.
  • Set the frequency to “Every Day” and the time to “12:00 PM”.
Click on the “Save” button to schedule this workflow. With this setup, Pabbly Connect will trigger the workflow daily at noon to generate a new blog title.
3. Generating Blog Title Using OpenAI
After scheduling, click on “Add New Action Step” and search for OpenAI. Select OpenAI and choose the event as “Chat GPT”. Click on “Connect” to link your OpenAI account.
You will need to create a new OpenAI API key. Click on the “OpenAI API Key” page, then on “Create New Secret Key”. Name your key and click on “Create Secret Key”. Copy the generated key and paste it in your Pabbly Connect workflow.
4. Generating Blog Content with OpenAI
Next, clone the previous action step to generate the blog content. In the prompt section, input the blog title generated earlier. This allows the content to be tailored to the specific title.
To map the blog title dynamically, use the slash (/) and select the title from the OpenAI response. Click on “Save and Send Test Request” to receive the blog content. Pabbly Connect will handle the data mapping automatically, ensuring your content is unique each day.
5. Posting the Blog on Google Blogger
To post the generated blog on Google Blogger, add another action step and select Google Blogger. Choose the event as “Create a Post” and connect your Google account.
Map the title and content from the OpenAI response. Set the status to “Draft” if you want to review it before publishing. Click on “Save and Send Test Request” to finalize the post. Your new blog will appear on Google Blogger once you refresh the page.
Using Pabbly Connect allows you to automate blog posting efficiently. By integrating OpenAI and Google Blogger, you can generate and draft unique blogs daily without manual effort. Start your free trial today and streamline your blogging process!
