To start integrating Facebook Lead Ads with Google Sheets, first, you need to access Pabbly Connect. If you are an existing user, simply log into your dashboard. If you’re new, visit pabbl.com/connect to sign up for free.
Once signed in, you will have access to 100 free tasks each month, allowing you to explore the capabilities of Pabbly Connect. After familiarizing yourself with the platform, you can consider upgrading to a subscription plan if you find it beneficial.
2. Creating a Workflow Using Pabbly Connect
To create a new workflow in Pabbly Connect, you can either start from scratch or use the AI workflow builder. For this tutorial, we will use the AI option. Simply enter your requirement, such as adding Facebook leads to Google Sheets.
- Select the trigger as “New Lead” from Facebook Lead Ads.
- Choose the action as “Add Row” in Google Sheets.
- Click on “Approve and Create” to finalize the workflow.
After creating the workflow, you will see it listed on your dashboard. This is where you will connect your applications to automate the process using Pabbly Connect.
Next, you need to connect your Facebook Lead Ads to Pabbly Connect. Click on the Facebook Lead Ads option and then select the “Connect” button. You will need to log into your Facebook account to authorize the connection.
Once logged in, select the page and the lead form you are using. If no options appear, click on “Refresh Fields” to load them. After selecting your page and lead form, choose the response format as simple and click on “Save and Send Test Request”.
4. Capturing Lead Details in Pabbly Connect
After sending the test request, Pabbly Connect will wait for a webhook response. To generate this response, you need to create a test lead using the Facebook Lead Ads Testing Tool. Enter the required information and submit the form.
Once the lead is submitted, Pabbly Connect will capture the details automatically. You can then proceed to add these details into your Google Sheets. This automation ensures that every new lead is recorded without manual effort.
5. Adding Leads to Google Sheets Using Pabbly Connect
To add captured lead details into Google Sheets, click on the Google Sheets option in Pabbly Connect. If you haven’t connected it yet, select “Add a New Connection” and sign in with your Google account.
- Choose the spreadsheet where you want to store the lead details.
- Map the fields from the lead details to the corresponding columns in your sheet.
- Click on “Save and Send Test Request” to finalize the addition.
After completing these steps, you will find the lead details populated in your Google Sheets. This automation allows you to manage your leads efficiently, ensuring no lead is missed.
In this tutorial, we explored how to integrate Facebook Lead Ads with Google Sheets using Pabbly Connect. By automating this process, you can efficiently manage your leads and ensure timely follow-ups. Start leveraging Pabbly Connect today for seamless integration!
