To begin, you need to access Pabbly Connect. Open a new tab and navigate to pabblabi.com/connect. If you’re a new user, sign up for a free account to get started. This account will provide you with 100 free credits every month, perfect for testing your automation workflows.
Once logged in, you will see the dashboard of Pabbly Connect. Here, you can manage all your automation workflows. To create a new workflow, click on the “+ Create Workflow” button. You will have three options: create from scratch, create using AI, or create using quick builder. For this tutorial, we will use the quick builder for its efficiency.
2. Setting Up Your Workflow in Pabbly Connect
In the quick builder, enter a prompt like “instantly respond to Facebook leads using WhatsApp automation”. Pabbly Connect will analyze your request and suggest relevant triggers. Select the Facebook lead ads trigger as “New Lead”.
- Choose the Facebook page where your ads are running.
- Select the lead generation form you are using.
- Choose the response format (simple, advanced, or raw).
After making these selections, click on the “Save and Send Test Request” button. You will receive a positive response, indicating that the connection is successfully established.
3. Connecting WhatsApp Using Pabbly Connect
Next, we will connect WhatsApp through Pabbly Connect using Pabbly Chatflow. Click on the application and then the “Connect” button. You will need to add a new connection by clicking on “Add New Connection”.
Here, you will be prompted to enter your API token from Pabbly Chatflow. To get this token, log in to your Pabbly Chatflow dashboard and navigate to the settings option. Under the API and Webhooks section, you will find your API token. Copy it and paste it into the required field in Pabbly Connect.
4. Mapping Data for WhatsApp Messages
Once connected, you need to map the data received from Facebook leads to WhatsApp. In the recipient WhatsApp mobile number field, map the mobile number from the lead form. This mapping is essential as it allows Pabbly Connect to send personalized messages based on the lead’s submitted information.
- Enter a personalized message for the lead.
- Use mapping to include the lead’s name and location in the message.
- Ensure the mobile number includes the country code without the plus sign.
After completing the mapping, click on the “Save and Send Test Request” button. You should receive a successful response, confirming that the message was sent to WhatsApp.
5. Finalizing Your Pabbly Connect Workflow
After testing, ensure to enable the toggle for your workflow in Pabbly Connect. This step is crucial because if the toggle is disabled, your automation will not run. With everything set up, your workflow is now fully operational.
If you encounter any issues during this process, feel free to reach out for assistance. Remember, the power of Pabbly Connect lies in its ability to automate thousands of applications without coding, enhancing your business efficiency.
Integrating WhatsApp with Facebook leads using Pabbly Connect automates your messaging process, ensuring timely responses to potential customers. This setup enhances customer engagement and streamlines your sales process. Try it out today for a more efficient workflow!
