1. Accessing Pabbly Connect for Stock Alerts
To start receiving stock alerts on WhatsApp, you need to access Pabbly Connect. First, log in to your Pabbly Agentic AI dashboard. If you’re a new user, visit the landing page to get started. Click on the “Get Started” button to explore the available plans.
Once on the plans page, you can opt for a free trial of Pabbly Connect. This allows you to test its features before making a purchase. After selecting the free trial, you’ll be directed to create an account, enabling you to utilize the automation features offered by Pabbly.
After accessing your dashboard, click on “Create Workflow” to initiate the process. Name your workflow something like “Get Alerts on WhatsApp” to define its purpose. In the description, specify that you want to receive stock alerts every hour on WhatsApp.
- Enter the title of your workflow.
- Describe the alerts you wish to receive.
- Specify the stocks you want alerts for, like the top 10 NIFTY 50 stocks.
By setting up this workflow in Pabbly Connect, you will automate the process of fetching stock data and sending it directly to your WhatsApp. This saves you the hassle of checking stock prices manually.
3. Fetching Stock Data Using Pabbly Connect
To receive stock alerts, Pabbly Connect will utilize a free stock API to fetch the required data. You will need to specify the criteria for the stocks, such as choosing the biggest gainers. This is a crucial step in ensuring you receive relevant stock updates.
Once the criteria are set, you will be prompted to enter your API key from Pabbly Chartflow. Follow these steps to locate your API key:
- Log in to your Pabbly Chartflow account.
- Navigate to Settings and select API Settings.
- Copy your API key from Developer Settings.
After obtaining your API key, paste it into Pabbly Connect to establish a connection. This integration allows you to pull real-time stock data seamlessly.
4. Integrating WhatsApp with Pabbly Connect
Next, you will need to integrate WhatsApp into your workflow using Pabbly Connect. Enter the recipient’s WhatsApp number where you want to receive alerts. Make sure to specify that you want alerts sent directly to your number, rather than a group chat.
To finalize the integration, you will also need to provide the WhatsApp channel ID and base URL. Follow the prompts in Pabbly Connect to obtain this information from the API documentation provided by Pabbly Chartflow. This step ensures that your alerts are sent accurately and reliably.
Once all details are entered, Pabbly Connect will test the connection. If everything is set up correctly, you will receive a test message on WhatsApp confirming the successful integration.
5. Testing and Scheduling Alerts
After successfully integrating WhatsApp, it’s time to test the workflow. Use the “Test it” option in Pabbly Connect to verify that you receive stock alerts as expected. If the test is successful, you will see a message indicating that the WhatsApp message was sent.
Once testing is complete, you can schedule your alerts to be sent every hour. Simply type “Schedule this workflow” in the chat, and Pabbly Connect will automate the process of sending stock updates to your WhatsApp at regular intervals.
This feature allows you to stay updated on stock prices without any manual effort. You can customize the workflow further based on your preferences, including changing the stock provider if needed.
In conclusion, using Pabbly Connect to set up automatic stock alerts on WhatsApp is a straightforward process. By following the steps outlined, you can ensure timely updates on your favorite stocks without constant manual checking. This automation enhances your trading experience and keeps you informed effortlessly.
