1. Setting Up Pabbly Connect for Google Ads Integration
To set up instant lead alert notifications, start by accessing Pabbly Connect. This integration platform allows you to connect Google Ads with Slack seamlessly.
Open your workflow builder in Pabbly Connect and click on the “Add Trigger” button. Select Google Ads as the trigger application and choose the event as “New Lead Form Entry”. Click on “Connect” to generate a webhook URL.
2. Configuring Google Ads to Use Pabbly Connect
Once you have the webhook URL from Pabbly Connect, navigate to your Google Ads campaign. Ensure you have a lead form added to your campaign, as this is crucial for connecting Google Ads with Pabbly Connect.
Scroll down to the lead delivery section and paste the webhook URL into the designated field. Enter the required key and click on “Send Test Data” to verify the connection. This step confirms that Google Ads is properly linked with Pabbly Connect.
  • Open your Google Ads campaign.
  • Locate the lead delivery option.
  • Paste the webhook URL and enter the key.
  • Click “Send Test Data” to test the connection.
After sending the test data, return to Pabbly Connect to verify that the test data has been captured. You should see details like the city, phone number, email, and name of the lead, confirming a successful connection.
3. Setting Up Slack Notifications Using Pabbly Connect
Next, to notify your team on Slack, click on the “Add Action” button in Pabbly Connect. Select Slack as the action application and choose “Send Channel Message” as the event.
Click on “Connect” and then add a new connection to Slack. You will need to specify the token type, which can be either user or bot. For this example, select “bot” and enter it into the field provided.
  • Select Slack as the action application.
  • Choose “Send Channel Message” as the event.
  • Add a new connection and specify the token type as “bot”.
Ensure that your Slack account is logged in before proceeding. Allow Pabbly Connect to access your Slack account, ensuring that all permissions are granted for a smooth integration.
4. Customizing Your Slack Message with Pabbly Connect
Now it’s time to customize the message that will be sent to your Slack channel. In the channel selection, choose the appropriate channel, such as “New Leads”.
Craft your message by dynamically inserting the lead details captured from Google Ads. You can map the data by entering a slash and searching for the corresponding fields like name, phone number, email, and city.
For example, your message could say: “New lead from Google Ads: Name, Phone Number, Email, City. Let’s connect with the buyer as soon as possible!” This dynamic mapping ensures that every new lead notification is personalized and relevant.
5. Testing and Finalizing Your Pabbly Connect Automation
After setting up the message, click on “Save and Send Test Request” in Pabbly Connect. This action will send a test message to your selected Slack channel to verify that everything is working correctly.
Check your Slack channel to confirm that the message has been received. If successful, this means your automation is ready to go live, and your team will be notified instantly whenever a new lead comes in from Google Ads.
By using Pabbly Connect, you can also integrate other applications like Facebook Lead Ads, Instagram Lead Ads, and more, making it a versatile tool for your business needs.
In this tutorial, we explored how to create instant lead alert notifications using Pabbly Connect. By integrating Google Ads with Slack, you can ensure your team is promptly notified about new leads, enhancing your response time and efficiency.
