To start automating product descriptions, access Pabbly Connect by visiting pabbl.com/connect. If you are a new user, click on the “Sign Up for Free” button in the top right corner.
This will allow you to create an account and explore 100 tasks free each month. Once signed up, you can easily set up your automation workflows using Pabbly Connect.
After accessing Pabbly Connect, navigate to the workflow builder. This interface is where you will set up your automation processes. The first step is to add a trigger by clicking the “Add Trigger” button.
  • Choose “New or Updated Spreadsheet Row” as the trigger event.
  • Click on “Connect” to establish a connection.
Once the connection is established, you will receive a webhook URL. Copy this URL to integrate it with your Google Sheets.
3. Setting Up Google Sheets with Pabbly Connect
Open your Google Sheets and go to “Extensions” > “Add-ons” > “Get add-ons”. Search for “Pabbly Connect Webhooks” and install it. After installation, refresh your spreadsheet.
Navigate to “Extensions” > “Pabbly Connect Webhooks” > “Initial Setup”. Paste the copied webhook URL and specify the trigger column, which is where the data will be sent from Google Sheets to Pabbly Connect.
  • Enter the trigger column (e.g., “F”).
  • Click “Submit” to save the setup.
After setting up, click the “Send Test” button to capture the test data. This will ensure that the connection between Google Sheets and Pabbly Connect is functioning correctly.
4. Generating Product Descriptions Using Gemini AI
Next, add a new action step in your workflow by selecting Gemini as the action application. Choose “Generate Content” as the event and connect it to Pabbly Connect.
If prompted, enter your API key from Google AI Studio to establish the connection. You can find this by navigating to the “Get API Key” section in Google AI Studio.
  • Copy the API key and paste it into Pabbly Connect.
  • Map the product details such as name, category, and features from the previous step.
This mapping allows Pabbly Connect to dynamically generate product descriptions based on the data from Google Sheets. After mapping, click “Save and Send Test Request” to generate the product description.
5. Updating Google Sheets with Generated Descriptions
To save the generated descriptions back into Google Sheets, add another action step. Select Google Sheets and choose “Update Cell Value” as the event.
Connect to your Google account and select the spreadsheet and sheet where you want to update the data. Specify the cell range where the description will be added, ensuring that you map the row index dynamically.
  • Set the column name (e.g., “G”).
  • Map the generated description value.
Click “Save and Send Test Request” to confirm that the description has been successfully added to your Google Sheets. This integration allows for seamless updates every time new product details are added.
By utilizing Pabbly Connect, you can automate the process of generating product descriptions using Google Sheets and Gemini AI. This setup not only saves time but also enhances productivity by streamlining your workflow.
