To start automating your content ideas, you need to access Pabbly Connect. If you are a new user, open your browser and search for pabbl.com/connect. Click on the “Sign Up for Free” button in the top right corner to create an account.
Once registered, you will receive 100 free tasks each month. This allows you to test Pabbly Connect and explore its features. If you enjoy the service, consider purchasing a subscription plan, especially with available discount codes for significant savings.
2. Setting Up Your Workflow in Pabbly Connect
After logging into Pabbly Connect, navigate to the workflow builder. This is where you will create your automation by setting up triggers and actions. Click on the “Add Trigger” button to begin.
  • Choose “Schedule by Pabbly” as your trigger application.
  • Select “Schedule Workflow” as your event.
  • Set the frequency to run daily at 12 p.m.
Click “Save” to confirm your settings. This setup ensures that your workflow will trigger daily, allowing you to generate content ideas consistently.
3. Integrating Google Gemini with Pabbly Connect
Next, you will integrate Google Gemini into your workflow. Click on “Add New Action Step” and search for “Gemini.” Choose it as your action application and select the event “Generate Content.” Click on “Connect” to proceed.
If you have an existing connection, select it. If not, create a new connection by entering your API key from Google AI Studio. You can find this key by navigating to the “Get API Key” section in your Google AI Studio account.
  • Name your key and select your project.
  • Click on “Create Key” and copy the generated key.
Paste the API key into Pabbly Connect and click “Save”. This connection allows Pabbly Connect to generate content ideas using the Gemini AI.
4. Sending Generated Content Ideas to Slack
Now that you have generated content ideas using Gemini, the next step is to send these ideas to your Slack channel. Add another action step and search for “Slack.” Choose it as your action application and select “Send Channel Message” as the event.
Connect to Slack by selecting an existing connection or creating a new one. You will need to enter the token type (either user or bot). Ensure you log in to your Slack account and grant necessary permissions to Pabbly Connect.
  • Select the appropriate Slack workspace.
  • Choose the channel where the message will be sent.
  • Map the generated content idea to the message field.
Click on “Save and Send Test Request” to ensure everything is working correctly. You should see the message appear in your Slack channel, confirming the automation is functioning as intended.
5. Conclusion
In this tutorial, you learned how to automate the generation of content ideas using Pabbly Connect by integrating Google Gemini and Slack. This workflow allows you to receive daily content ideas directly in your Slack channel, streamlining your content creation process.
By leveraging Pabbly Connect, you can enhance your productivity and automate tasks effortlessly. Try this setup today to experience the magic of automation!
