1. Creating Your AI Agent with Pabbly Connect
To create your first AI agent, you will need to access Pabbly Connect. This platform allows seamless integration between various applications, including Pabbly Chatbot and OpenAI API. Start by logging into your Pabbly account and navigate to the Pabbly Chatbot section.
Once in Pabbly Chatbot, click on the “Add Smart Assistant” button. You will be prompted to name your assistant descriptively. After naming, select the type of instruction you want the AI agent to follow. Choose the “AI Agent” option to set the foundational rules for your agent’s behavior.
2. Setting Instructions for Your AI Agent Using Pabbly Connect
In this step, you will configure how your AI agent responds to users. Using Pabbly Connect, you can set specific instructions that will dictate the AI’s responses. This includes defining the temperature of the responses, which controls the creativity level of the AI.
  • Select a temperature setting (0.5 is recommended for balanced responses).
  • Choose OpenAI as your AI service provider.
  • Select the AI version, preferably GPT-4 or mini.
After making these selections, you will need to provide an API Key from OpenAI. This key is essential for connecting your Pabbly Chatbot with OpenAI services through Pabbly Connect.
3. Setting Up Your OpenAI API Key with Pabbly Connect
To obtain your OpenAI API Key, navigate to the OpenAI API page. Click on “Create New Secret Key” and fill in any optional details. After creating the key, copy it to your clipboard. This key will be used to establish a connection between Pabbly Connect and OpenAI.
Return to Pabbly Connect, where you will paste the API Key into the designated field. Click the “Connect” button to link your OpenAI account with your Pabbly Chatbot. This step is crucial for enabling your AI agent to utilize OpenAI’s capabilities.
4. Configuring Knowledge Base for Your AI Agent in Pabbly Connect
The knowledge base is the core of your AI agent’s functionality. Using Pabbly Connect, you can upload a file containing all necessary information about your services. This file serves as a reference for your AI agent to provide accurate responses.
To upload your knowledge base, click on “Add New File” and select the appropriate document from your device. Ensure that this document contains detailed information about your offerings, such as services, courses, and pricing. This step is vital for your AI agent to deliver precise and relevant answers.
  • Ensure the knowledge base is comprehensive and relevant to your business.
  • Upload the document in a compatible format.
  • Select the uploaded file and click “Insert” to finalize.
After uploading your knowledge base, your AI agent will be equipped to handle user inquiries effectively, providing tailored responses based on the uploaded information.
5. Finalizing Your AI Agent Configuration in Pabbly Connect
In the final step, you will customize the interface of your AI agent. Using Pabbly Connect, you can modify the appearance by adding titles, subtitles, and welcome messages. This customization enhances user interaction and provides a professional look.
Once you are satisfied with the design, activate your AI agent by toggling the activation switch. Finally, click on the “Save Smart Assistant” button to ensure all your settings are stored. This step completes the setup process for your AI agent.
After saving, navigate to the settings section in Pabbly Chatbot to configure auto-reply settings. Make sure to enable the option for AI assistant responses, selecting the appropriate contacts for interaction. Save these rules, and your AI agent will be ready to assist users around the clock.
Creating your first AI agent without coding is made easy with Pabbly Connect. By following these steps, you can integrate Pabbly Chatbot and OpenAI API seamlessly, allowing your AI agent to provide accurate and timely responses. Start automating your business interactions today!
