To create viral Pinterest pins, you first need to access Pabbly Connect. If you’re an existing user, simply open your workflow. For new users, visit pabbl.com/connect to sign up for free and explore the platform.
Once you’re on the Pabbly Connect landing page, click on the “Sign Up for Free” button. You will receive 100 free tasks each month to get started. This is a great way to explore how Pabbly Connect can automate your tasks without any initial investment.
The next step in using Pabbly Connect is to set up a trigger for your workflow. Click on the “Add Trigger” button and select “Scheduled by Pabbly” as your trigger application. Then choose the event as “Scheduled Workflow”.
- Select how often you want the workflow to run, e.g., daily at 12:00 PM.
- Click on the “Save” button after making your selection.
This setup allows Pabbly Connect to automate the process of creating and posting viral Pinterest pins at your specified time.
3. Generating Content with Google Gemini
After setting up the trigger, the next action in Pabbly Connect is to generate the pin’s description. Click on “Add New Action Step” and search for “Google Gemini”. Choose the event as “Generate Content” and connect it.
If you haven’t created a connection yet, you will need to enter your API key from Google AI. Navigate to Google AI Studio, go to Settings, and click on “Get API Key”. After creating your key, paste it into Pabbly Connect to establish the connection.
4. Generating the Image with Google Gemini
Next, you will generate the image for your Pinterest pin using the same Google Gemini integration. Click on “Add New Action Step” again and select Google Gemini, but this time choose the event as “Generate and Edit Image”.
- Select the model as “Nano Banana Pro” for image generation.
- Map the previously generated description from the last step.
After clicking on “Save and Send Test Request”, you will receive the image URL in the response, which you can then use to post on Pinterest.
5. Posting the Generated Pin on Pinterest
Finally, use Pabbly Connect to post your newly created pin on Pinterest. Click on “Add New Action Step” and select Pinterest as your action application. Choose the event as “Create a Pin” and connect your Pinterest account.
Once connected, select the board where you want to post your pin. Map the image URL and description generated earlier. After setting everything up, click on the “Save and Send Test Request”. You will receive a confirmation that your pin has been successfully posted on Pinterest.
In this tutorial, we explored how to automate the creation of viral Pinterest pins using Pabbly Connect. By integrating various applications, you can streamline your workflow and enhance your marketing efforts effortlessly.
