To start using Pabbly Connect, open a new tab in your browser and type pabbly.com/connect. This will take you to the Pabbly Connect landing page where you can manage integrations.
If you’re a new user, click on the “Sign Up for Free” button to create an account. Existing users can simply click on “Sign In” to access their dashboards. By signing up, you’ll receive 100 free tasks per month to start automating your workflows.
Once logged in, you will see the Pabbly Connect dashboard. To create a new workflow, click on the “Create Workflow” button. You can choose to build from scratch or use the Fabric Quick Workflow Builder for easier setup.
  • Select your trigger application as “Schedule” to set the frequency for creating new Pinterest pins.
  • Choose the time and frequency for the workflow to run, e.g., daily at 11:00 AM.
  • Click on “Save” to finalize your workflow settings.
After setting this up, your workflow will be ready to generate new pins on a daily basis automatically. The next step involves setting up the content generation using Google AI Studio.
3. Generating Content with Google AI Studio
In this step, you will use Google AI Studio to generate content for your Pinterest pins. In the Pabbly Connect workflow, select Google AI Studio as the next application after your trigger.
To connect Google AI Studio, click on “Add New Connection” and enter the API key from Google AI Studio. You will need to create an API key if you don’t have one already. Once connected, input the prompt for generating content.
  • Enter a descriptive prompt, such as “Generate a unique Pinterest pin caption related to fashion trends.”
  • Select the model version, like “2.5 Flash,” for optimal results.
  • Click on “Save and Send Test Request” to generate the content.
This will provide you with a caption that will be used for the Pinterest pin. Ensure to copy this caption for the next steps in your workflow.
4. Creating a Pinterest Pin Using Pabbly Connect
Now that you have your content generated, it’s time to create the actual Pinterest pin. In your Pabbly Connect workflow, select Pinterest as the next application.
To connect Pinterest, click on “Add New Connection” and authorize Pabbly Connect to access your Pinterest account. Choose the board where you want to post the pin and map the image URL and description generated in the previous steps.
  • Select the board name, for example, “Digital Marketing.”
  • Map the image URL generated from Google AI Studio to the pin creation fields.
  • Finally, click on “Save and Send Test Request” to create the pin.
Once the request is successful, your pin will be posted on your Pinterest board automatically, completing the workflow.
5. Conclusion: Automate Your Pinterest Workflow with Pabbly Connect
By following these steps, you can automate the process of creating Pinterest pins using Pabbly Connect, Google AI Studio, and Pintest. This integration allows you to generate content and images daily without manual effort.
Utilizing Pabbly Connect not only saves time but also enhances your marketing efforts by ensuring consistent and fresh content on your Pinterest account. Start automating today to see the benefits for your business!
