1. Accessing Pabbly Connect for Blog Automation
To start automating your blog posts, access Pabbly Connect by visiting pabbly.com/connect. Here, you can sign up for a free trial, allowing you to create up to 100 blogs without any cost.
Once signed up, log into your Pabbly Connect dashboard. From there, you can create a new workflow by selecting “Create from Scratch” and naming it, for example, “AI Blogs”. This is the first step towards automating your blog posts.
2. Setting Up a Scheduled Trigger in Pabbly Connect
Now that you have your workflow named, it’s time to set up a trigger. In your workflow, click on the “Add Trigger” button and select “Schedule”. This allows you to automate the process of posting blogs daily.
  • Choose “Schedule Workflow” as the event.
  • Select how often you want the workflow to run, preferably daily.
  • Set the specific time for when you want the workflow to execute.
After setting this up, click the “Save” button. Your workflow is now scheduled to run automatically at your specified time every day.
3. Generating AI Content for Blog Posts
With the trigger set, the next step is to generate content using AI. Click on “Add New Action Step” and select your preferred AI tool. For this tutorial, we will use OpenAI, but you can also choose other tools like Gemini.
To connect your AI tool, you will need an API key. Go to the AI tool’s website, create a new secret key, and paste it back into Pabbly Connect. This step is crucial as it allows Pabbly Connect to communicate with the AI tool effectively.
  • Select “Generate Content” as the event.
  • Input the prompt for generating the title and content.
  • Click on “Save and Send Test Request” to test the connection and get your generated content.
Once the AI generates the title and content, you can proceed to the next step of posting this content to your blog.
4. Posting Generated Content to Google Blogger
After generating your blog content, it’s time to post it to Google Blogger. Click on “Add New Action Step” again and search for Google Blogger. Select “Create a Post” as the event.
You will need to sign in with the Google account linked to your Blogger. Once authenticated, choose your blog ID from the dropdown. Then, map the title and content generated by the AI tool into the respective fields.
  • Map the title generated by the AI tool to the “Title” field.
  • Map the content generated to the “Content” field.
  • Choose whether to save the post as a draft or publish it live.
Once you have mapped all the required fields, click on “Save and Send” to finalize the post. Your blog post will now appear on Google Blogger as per your settings.
5. Conclusion: Automating Your Blogging Process
In this tutorial, you learned how to automate daily AI blog posts using Pabbly Connect. By integrating Pabbly, Google, and Gmail, you can effortlessly generate and post content without manual intervention.
With just a one-time setup, you can streamline your blogging process and focus on other important tasks. Try out Pabbly Connect today and enhance your blogging experience!
