1. Creating Your AI Assistant with Pabbly Connect
To create an AI assistant using Pabbly Connect, you need to start by accessing the Pavi Chatflow platform. This platform allows you to automate customer interactions on WhatsApp effectively. After signing up, you will be directed to the dashboard where you can add your WhatsApp number.
Once your WhatsApp number is integrated, you can select the AI assistant feature from the left-hand menu. This section is crucial as it allows you to set up the AI assistant to respond to customer queries based on your business information.
2. Configuring Your AI Assistant in Pabbly Connect
In this section, you will configure the settings of your AI assistant. Begin by selecting the instruction type as AI agent in Pabbly Connect. This selection enables your assistant to function effectively. You can modify the instructions to suit your business needs.
- Set the temperature to adjust creativity: 0 means focused, while 1 is more creative.
- Select the AI model from OpenAI that you want to use.
- Input your API key from OpenAI to enable responses.
After configuring these settings, ensure to save your AI assistant settings in Pabbly Connect. This will help in managing customer interactions seamlessly.
3. Building Your Knowledge Base with Pabbly Connect
Creating a knowledge base is essential for your AI assistant to provide accurate responses. In Pabbly Connect, you can upload your business information in the form of a text or PDF file. This document will serve as the brain of your AI assistant.
Make sure to include all relevant details such as services offered and FAQs. Once uploaded, your AI assistant will fetch data from this knowledge base to answer customer queries effectively.
4. Styling Your AI Assistant Using Pabbly Connect
To enhance user experience, you can customize the appearance of your AI assistant in Pabbly Connect. This includes choosing a theme, assistant shape, and colors. You can also upload profile pictures for both the header and the assistant.
Additionally, you can set initial messages that greet users when they start a chat. This personalization helps make the interaction more engaging and user-friendly.
5. Embedding Your AI Assistant with Pabbly Connect
After creating and styling your AI assistant, the final step is to embed it on your website. In Pabbly Connect, click on the embed button to obtain the script code. This code needs to be pasted into the JavaScript section of your website’s code.
Once embedded, your AI assistant will be live on your website, ready to assist customers through WhatsApp. This integration significantly enhances your customer service capabilities.
Integrating Here, Now, Pabbly, API, Means, Make, So Pabbly, OpenI API, So I, and Pavi Chatflow using Pabbly Connect provides an efficient solution for automating customer interactions. By following the steps outlined, you can create a responsive AI assistant that enhances customer engagement.
