1. Accessing Pabbly Connect to Create an AI Chatbot
To create an AI Chatbot, start by accessing Pabbly Connect. Navigate to the Pabbly Chatbot landing page and sign up for free to get started.
Once you have signed up, log into your Pabbly Connect dashboard. Here, you will be able to add your WhatsApp number, which is essential for the chatbot functionality. This integration is key to ensuring your chatbot can interact with users effectively.
2. Setting Up Your AI Assistant in Pabbly Connect
After adding your WhatsApp number, go to the left sidebar and select the AI Assistant option. Click on ‘Add AI Assistant’ to start creating your chatbot.
  • Name your assistant and configure its settings.
  • Choose a custom prompt or select from pre-existing examples.
  • Set the temperature for responses, ranging from 0 to 1.
Configuring these settings allows you to tailor the chatbot’s responses according to your business needs. The temperature setting will affect how predictable or creative the chatbot’s replies will be.
3. Integrating OpenAI API with Pabbly Connect
Next, you need to integrate the OpenAI API within Pabbly Connect. Select OpenAI as your provider and choose your preferred model.
  • Obtain your OpenAI API key from the OpenAI API page.
  • Click on ‘Create New Secret Key’ to generate a new API key.
  • Copy and paste the key into the Pabbly Connect interface.
This integration is crucial as it allows your AI Chatbot to leverage OpenAI’s capabilities for generating intelligent responses. Make sure to save your configurations before proceeding.
4. Finalizing Your AI Chatbot Settings
In this step, you can add header and footer messages to your chatbot. These messages can provide additional context or instructions to users interacting with your AI.
  • Specify keywords that can stop the AI assistant from responding.
  • Set up a fallback message for when the API does not respond.
  • Define how many retry attempts before sending a fallback message.
These settings enhance the user experience by ensuring that the chatbot can handle various scenarios effectively. Once you have configured these settings, click ‘Save AI Assistant’ to finalize the setup.
5. Embedding Your AI Chatbot on Your Website
Now that your AI Chatbot is ready, you need to embed it onto your website. Go to the ‘Embed It’ section in Pabbly Connect to find the script.
Simply copy the provided script and paste it into your website’s HTML. This will allow the AI Chatbot to appear on your site, ready to interact with visitors. When users click the WhatsApp logo, the chatbot will initiate a conversation based on the initial message you set.
In just three minutes, you can create an AI Chatbot using Pabbly Connect, integrating it seamlessly with OpenAI. This powerful combination enhances customer interaction and streamlines communication.
