To begin, open your browser and navigate to Pabbly Connect by searching for pabbly.com/connect. If you’re a new user, click on the “Sign up for free” button on the top right corner. This allows you to explore Pabbly Connect with up to 100 tasks for free each month.
Once you have signed up, you can start creating your automation workflows. Existing users can directly access their workflow builder. The intuitive interface of Pabbly Connect will guide you through the setup process.
2. Creating Your First Workflow in Pabbly Connect
In the workflow builder of Pabbly Connect, you need to set up your trigger and action. The trigger is the event that starts your automation, while the action is what happens next. For this tutorial, we will schedule a Facebook post every day.
  • Select “Schedule” as your trigger application.
  • Choose the frequency, for example, every day at 1:00 PM.
  • Click on “Save” to confirm your trigger settings.
Your workflow is now set to run daily at the specified time. This is the first step in automating your Facebook posts using Pabbly Connect.
3. Generating AI Content for Facebook Posts
Next, you will need to generate content for your Facebook posts using an AI tool integrated with Pabbly Connect. Click on “Add New Action Step” and select Gemini as your action application.
To connect Gemini, you will need to provide an API key from Google AI studio. Follow these steps:
  • Go to Google AI studio and navigate to the “Get API Key” section.
  • Create a new API key and copy it.
  • Paste the API key into the connection settings in Pabbly Connect.
Once connected, enter your prompt for content generation and select the model you wish to use. Click on “Save and Send Test Request” to generate your post content.
4. Posting Generated Content to Facebook
After generating your content, the next step is to post it to your Facebook page through Pabbly Connect. Click on “Add New Action Step” again and select Facebook Pages as your action application.
To connect your Facebook account, ensure you are logged in, then click on “Add a New Connection”. Follow the prompts to authorize Pabbly Connect to access your Facebook pages.
  • Select the Facebook page you want to post to (e.g., Stacy Drape).
  • Map the generated content from the previous step into the message field.
  • Click on “Save and Send Test Request” to post your message.
Upon successful posting, you will see your new content on your Facebook page, demonstrating the power of automation through Pabbly Connect.
5. Conclusion: Automate Your Facebook Posts with Pabbly Connect
By following these steps, you have successfully set up an automated workflow using Pabbly Connect to generate and post content on Facebook. This process not only saves time but also enhances your social media engagement effortlessly.
Explore more automation possibilities with Pabbly Connect and take your social media strategy to the next level. Start automating today and experience the benefits of seamless integration!
