1. Accessing Pabbly Connect for Workflow Creation
To create a workflow in Pabbly Connect, first, access the Pabbly Connect dashboard. Open a new tab and navigate to Pabbly Connect by entering ‘pabbly.com/connect’. This will direct you to the landing page where you can either sign in or sign up for a free account.
If you’re new, click on the “Sign Up Free” button to create your account. With your new account, you can access 100 free tasks per month, allowing you to explore Pabbly Connect and create workflows without any cost. Existing users can simply click the “Sign In” button to access their dashboard.
Once logged into your Pabbly Connect account, you will see the dashboard. To start creating a workflow, click the “Create Workflow” button on the right side. You will have two options: “Create from Scratch” or “Create Using AI”. For this tutorial, we will use the AI option to build our workflow.
  • Select “Create Using AI” to automate the process.
  • Type your prompt describing the workflow you want to create.
  • Provide the details of the lead capture from Facebook Lead Ads to Google Sheets.
After entering your prompt, the AI will generate the workflow structure. Review it and click “Approve” to create your workflow. This feature of Pabbly Connect simplifies the workflow creation process significantly.
3. Setting Up the Trigger Application: Facebook Lead Ads
Now that your workflow structure is ready, the next step is to set up the trigger application, which in this case is Facebook Lead Ads. Ensure you are logged into your Facebook account where you have created lead forms. In Pabbly Connect, click on the “Connect” button next to Facebook Lead Ads.
You will see options to add a new connection or select an existing one. Choose “Add New Connection” and click the “Connect with Facebook Lead Ads” button. After a successful connection, select the page from which you want to capture leads and choose the specific lead form.
  • Choose the page name from which leads will be captured.
  • Select the lead generation form you wish to use.
  • Set the response format to “Simple” for better data handling.
After setting up the trigger, test the connection by submitting a test record. This step is crucial as it allows Pabbly Connect to capture the data from your Facebook Lead Ads effectively.
4. Setting Up the Action Application: Google Sheets
With the trigger set, it’s time to configure the action application, which is Google Sheets. In your Pabbly Connect dashboard, click on the “Connect” button next to Google Sheets. Again, select “Add New Connection” and sign in with your Google account.
Once connected, select the specific spreadsheet and sheet where you want the lead details to be added. For instance, if your spreadsheet is named “Worksheet” and the sheet is “New Leads”, select those accordingly. This setup ensures that every new lead captured will automatically populate in your designated Google Sheet.
  • Select the spreadsheet where you want to store leads.
  • Choose the specific sheet for data entry.
  • Map the fields correctly to ensure data integrity.
After mapping the fields, click “Save and Send Test Record” to verify that the integration works. This step confirms that your Google Sheets is successfully integrated with Pabbly Connect.
5. Completing Your Workflow in Pabbly Connect
Once you have set up both the trigger and action applications, your workflow is almost complete. The final step is to ensure that all details captured from Facebook Lead Ads are correctly added to your Google Sheets. Every time a new lead fills out the form, their information will automatically be recorded in your specified Google Sheet.
This automation not only saves time but also ensures that you have accurate and up-to-date information about your leads. With the help of Pabbly Connect, you can manage your leads efficiently and without hassle.
Now that your workflow is set up, you can go back to your Pabbly Connect dashboard and monitor the performance of your integrations. Ensure that you utilize the 100 free tasks available to explore more features and capabilities of Pabbly Connect.
In conclusion, creating a workflow in Pabbly Connect to automate tasks between Facebook Lead Ads and Google Sheets is straightforward and efficient. By following these steps, you can streamline your lead management process and make better use of your time. Start utilizing Pabbly Connect today to enhance your business automation!
