To start creating a WhatsApp drip campaign, first, access Pabbly Connect. You can do this by visiting the Pabbly website and logging into your account. If you are a new user, sign up for a free trial which allows you to send up to 100 WhatsApp messages.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you will find various options to set up your integrations. Ensure your WhatsApp number is added in Pabbly Chatflow to facilitate sending messages seamlessly.
2. Creating a Drip Campaign in Pabbly Connect
Next, you will create a drip campaign using Pabbly Connect. Go to the “Flow” section and click on the “Add Flow” button. Name your flow appropriately, such as “WhatsApp Drip Campaign” to keep track of your automation.
  • Navigate to the “Flow” section.
  • Click on “Add Flow” and enter a name.
  • Select the trigger event as “WhatsApp template delivered”.
This trigger will start your drip campaign once the first WhatsApp message is delivered to the lead. Use the broadcast section of Pabbly Connect to send the initial message to your leads.
3. Setting Up Your Messages in Pabbly Connect
After setting the trigger, it’s time to configure the messages in your drip campaign. The first message will be sent immediately after the trigger. For subsequent messages, you will need to introduce delays. Use the “Delay” action node to set the time intervals between messages.
For example, if you want the second message to be sent one day after the first, select the delay type as “Delay for” and set the value to 1 day. Repeat this process for additional messages, adjusting the delays as needed.
  • Set the first message to send immediately.
  • Use “Delay” for subsequent messages.
  • Adjust delays based on your communication strategy.
Each message can be personalized using dynamic fields, such as the lead’s name, by using the “dollar name” variable in your messages. This ensures that each lead receives a personalized experience.
4. Finalizing Your Drip Campaign in Pabbly Connect
Once all messages and delays are set up, review the flow in Pabbly Connect. Ensure that each message is connected correctly with the appropriate delays. This step is crucial to maintain the sequence of messages being sent to your leads.
After verifying the setup, click the “Save Flow” button. This action will finalize your drip campaign, and it will be activated once the first WhatsApp template is delivered. You can customize the number of messages and their timing based on your business needs.
Remember, the maximum delay you can set is 30 days, but if you need longer intervals, you can use the “Delay until” option. This flexibility allows you to tailor your communication strategy effectively.
5. Benefits of Using Pabbly Connect for WhatsApp Drip Campaigns
Using Pabbly Connect for your WhatsApp drip campaigns offers numerous advantages. It automates the communication process, ensuring that leads are consistently engaged without manual effort. This approach not only saves time but also enhances the customer experience.
Additionally, with the ability to personalize messages and set specific delays, businesses can maintain a professional image while nurturing leads. The integration capabilities of Pabbly Connect make it a powerful tool for any business looking to streamline their communication efforts.
  • Automates communication with leads.
  • Enhances customer engagement.
  • Allows for personalized messaging.
Overall, utilizing Pabbly Connect can significantly improve your lead management process and drive better results for your business.
In conclusion, setting up a WhatsApp drip campaign using Pabbly Connect streamlines your communication with leads. This automation not only saves time but also enhances customer engagement through personalized messaging. Start utilizing Pabbly Connect today to improve your communication strategy.
