1. Accessing Pabbly Connect to Create Your WhatsApp AI Chatbot
To create a WhatsApp AI chatbot, you first need to access Pabbly Connect. Begin by searching for pabby.com/chartflow in your browser. This will direct you to the Pabbly Chartflow homepage.
On the homepage, you’ll see two options: “Sign In” and “Sign Up Free.” If you’re a new user, click on “Sign Up Free” to try out Pabbly Connect for free. Existing users can simply sign in to their accounts.
2. Setting Up WhatsApp Integration in Pabbly Connect
Once logged into Pabbly Connect, navigate to the “All Pabbly Apps” window. Click on “Access Now” under Pabbly Chartflow to reach the dashboard. Here, you will connect your WhatsApp number by clicking the add button.
- Select the method for connecting your WhatsApp number.
- Follow the prompts to complete the integration.
- Ensure your WhatsApp number is active for testing.
This setup allows Pabbly Connect to facilitate seamless communication between your WhatsApp and the chatbot functionalities.
3. Creating Your AI Assistant in Pabbly Chartflow
To create your WhatsApp AI assistant, access the “AI Assistant” feature in Pabbly Connect. Click on the add button to start a new assistant. You will be prompted to name your assistant and then proceed to the configuration window.
In the AI instructions section, select the instruction type from the dropdown. You can opt for a custom prompt or one of the predefined options like “AI Agent” or “Customer Support Agent.” After selecting, Pabbly Connect will automatically update some basic instructions for your assistant.
4. Configuring AI Settings for Optimal Performance
Configuring your AI assistant’s settings is crucial for effective communication. In the AI configuration section, set the temperature to determine how creative the responses will be. A lower temperature offers more focused responses, while a higher temperature allows for creativity.
Next, select the AI to use, such as OpenAI, and choose the model accordingly. You will need to input your OpenAI API key to connect the AI to Pabbly Connect. This API key can be obtained from your OpenAI account by creating a new secret key.
- Add a header message and footer message for your assistant.
- Specify stop keywords that will allow users to stop the assistant.
- Set retry attempts and fallback messages for API failures.
These configurations ensure that your WhatsApp AI chatbot operates smoothly and effectively, enhancing user experience through Pabbly Connect.
5. Activating and Assigning Your Assistant to WhatsApp Chats
After configuring your AI assistant, the next step is to activate it. Turn on the activation button and click the save button to finalize your settings in Pabbly Connect.
To assign your assistant to WhatsApp chats, navigate to the inbox settings. Here, enable the auto-reply feature, select your contact list, and assign the assistant. For bulk assignments, this method is effective. Alternatively, you can assign the assistant to individual chats by selecting them in the inbox.
Once the assistant is assigned, it will automatically respond to queries on WhatsApp, providing instant replies to customers. This integration showcases the power of Pabbly Connect in automating customer interactions.
In this tutorial, we explored how to create a WhatsApp AI chatbot using Pabbly Connect. By following the steps outlined, you can automate customer interactions effectively, enhancing your business operations.
