1. Accessing Pabbly Connect for Your Telegram Bot
To create your Telegram bot for free, start by accessing Pabbly Connect. Log into your Pabbly account and navigate to the workflow builder. This platform is essential for automating your messaging tasks.
Next, click on the ‘Add Trigger’ button. For the trigger application, select ‘Schedule’. This allows you to set up a workflow that runs at specific times, such as sending daily messages to your team.
2. Setting Up Your Scheduled Workflow in Pabbly Connect
In this step, you will configure the schedule for your Telegram bot messages. Choose the event as ‘Schedule Workflow’ and click on ‘Connect’. Set the frequency to daily and select the desired time, such as 4:00 PM.
  • Choose your preferred time for sending messages.
  • Select a frequency that suits your needs, like daily or weekly.
  • Ensure to save your settings after making changes.
Once you have configured the settings, click on the ‘Save’ button. Your workflow will now be scheduled to run at the specified time, ensuring your messages are sent automatically.
3. Integrating OpenAI with Pabbly Connect
The next step involves integrating OpenAI to generate the messages for your Telegram bot. Click on ‘Add New Action Step’ and select OpenAI as your action application. Choose the event as ‘Send GPT’. This integration is crucial as it provides the content for your messages.
To connect OpenAI, you will need an API key. Click on ‘Add New Connection’ and follow the prompts to generate your key from the OpenAI API key page. Once you have the key, paste it into Pabbly Connect and click ‘Save’.
After connecting, select the AI model you want to use, such as GPT-3. Enter your prompt for generating the message. This prompt will dictate the content sent to your Telegram group.
4. Creating Your Telegram Bot with Pabbly Connect
To send messages through Telegram, you first need to create a bot. Search for the BotFather in your Telegram app and click ‘Start’. Use the command ‘/newbot’ to initiate the bot creation process.
  • Name your bot appropriately, such as ‘Daily Message Bot’.
  • Choose a unique username ending with ‘_bot’.
  • Copy the API token provided by BotFather for future use.
Once the bot is created, you must add it to your Telegram group and promote it to admin. This step is vital for allowing the bot to send messages in the group.
5. Mapping Data in Pabbly Connect for Dynamic Messaging
The final step involves mapping the data from OpenAI to your Telegram bot. In Pabbly Connect, you need to input the chat ID of your group. This ID can be found in the URL of your Telegram group.
To map the dynamic message, use the slash command followed by the response from OpenAI. This ensures that each message sent to your group is unique and generated fresh each time.
After mapping the data, click on ‘Save and Send Test Request’. This will send a test message to your Telegram group. If successful, your bot is now ready to send messages daily at your chosen time.
By following this tutorial, you can effectively create a Telegram bot using Pabbly Connect. Automate your messaging and keep your team engaged effortlessly. With Pabbly Connect, integrating various applications is simple and efficient, allowing you to focus on what matters most.
