1. Setting Up Pabbly Connect for Discord Bot
To create a Discord bot, start by accessing Pabbly Connect. Open a new tab and navigate to pabbly.com/connect. Here, you will find the landing page for Pabbly Connect where you can sign up for a free trial.
After signing up, log in to your Pabbly Connect account and open your dashboard. From there, head to the workflow builder to create a new workflow. You will see a blank workflow where you can initiate the integration process.
2. Choosing the Trigger App: Schedule
In the workflow builder, click on the app trigger and select ‘Schedule’ as your trigger application. This is crucial as it determines how frequently your Discord bot will send messages. For daily messages, select ‘Schedule Workflow’ and set the frequency to ‘Every Day’.
  • Choose ‘Every Day’ for daily messages.
  • Select the time you want the messages to be sent.
Once you have configured the schedule, click on the save button. Your Pabbly Connect workflow is now set to send messages at the specified time each day.
3. Setting Up Open AI for Message Creation
Next, you need to choose the action application for generating messages. In this case, select ‘Open AI’ as your action app. This integration allows you to leverage AI to create engaging messages for your Discord channel.
Click on the connect button to set up a new connection. You will need your Open AI API key to proceed. To get this, log into your Open AI account and navigate to the API key page. Click on ‘Create New Secret Key’ and give it a name.
  • Select a project for your API key.
  • Set an expiration date for your key.
Once the key is generated, copy it and paste it into Pabbly Connect. Click save, and your Open AI integration will be established.
4. Connecting Discord to Pabbly Connect
After setting up Open AI, the next step is to connect Discord to your workflow. Choose ‘Discord’ as your application and select ‘Send Channel Message’ as the event. Click on the connect button to add a new connection.
Ensure you are logged into your Discord account, as Pabbly Connect will request permissions to access your server. Select your server and click continue, then authorize Pabbly to access your Discord account.
  • Choose the server where you want the bot to send messages.
  • Authorize all permissions requested by Pabbly Connect.
Once authorized, you will need to provide the Webhook ID and Webhook Token, which can be obtained from the channel settings in Discord. Create a new webhook and copy the URL provided, then paste it into Pabbly Connect.
5. Mapping Data and Testing the Integration
Now that Discord is connected, you need to map the data from Open AI to your Discord messages. This is where Pabbly Connect shines by allowing you to insert data dynamically into your messages.
In the message field, use the data from Open AI by selecting the response you received. This ensures that each message sent to Discord is unique and generated by AI. After mapping the data, click on the ‘Save and Send Test Request’ button to test the integration.
  • Click ‘Save and Send Test Request’ to verify the setup.
  • Check your Discord channel for the test message.
If everything is set up correctly, you will receive a message in your Discord channel from the bot. This confirms that your Pabbly Connect integration is working perfectly.
In this tutorial, you learned how to create a Discord bot using Pabbly Connect and integrate it with Open AI. By following these steps, you can automate message sending to your Discord channel effortlessly.
Utilizing Pabbly Connect makes the entire integration process seamless, allowing you to keep your community engaged with AI-generated content.
