To start the integration process using Pabbly Connect, first, open a new tab and navigate to pabbly.com/connect. This is where you can access the Pabbly Connect dashboard.
Once on the landing page, click on the “Sign Up for Free” option located at the top right corner. After signing up, log into your Pabbly Connect account and open your dashboard. From there, click on “Create Workflow” and select “Create from Scratch.” Name your workflow, for example, “Discord Bot,” and click on the create button.
In this section, we will set up the trigger for our workflow using Pabbly Connect. Click on “Add Trigger” and select “Schedule” as your trigger application. For the event, choose “Schedule Workflow” and click on “Connect.” Here, you can specify when you want this workflow to run.
- Select the time for the workflow to run, such as every day at 1:00 PM.
- Click on “Save” to confirm your settings.
Now, your workflow is scheduled to run daily at the specified time. This setup will allow you to generate a new message every day using AI, which will then be shared on your Discord channel.
3. Integrating Google AI with Pabbly Connect
Next, we will integrate Google AI using Pabbly Connect. Click on “Add New Action Step” and search for “Gemini” or any preferred AI application. Select it from the options, and for the event, choose “Generate Content.” Click on “Connect” to add a new connection.
To connect, you will need an API key from Google AI Studio. Go to Google AI Studio, navigate to the “Get API Key” section, and click on “Create API Key.” Name your key, select the project, and click on “Create Key.” Copy this key and paste it into Pabbly Connect. After entering the key, choose “Select Existing Connection” and click on “Save.”
4. Sending Messages to Discord Using Pabbly Connect
After generating content with Google AI, we will send the message to Discord through Pabbly Connect. Click on “Add New Action Step” again and search for “Discord.” Select it and choose “Send Channel Message” as your event. Click on “Connect” to establish the connection with Discord.
- Ensure your Discord account is logged in before starting the automation.
- Authorize Pabbly Connect by granting necessary permissions.
Once connected, obtain the webhook ID and token from your Discord channel. Go to the channel settings, click on “Integrations,” then “Webhooks,” and create a new webhook. Copy the webhook URL and paste it into Pabbly Connect. Extract the token and ID from the URL as instructed.
5. Mapping Data and Finalizing Workflow in Pabbly Connect
In this final step, we will map the generated message in Pabbly Connect. In the message section, instead of manually entering the text, use the mapping feature to insert data from the previous step. This ensures that every day, a new message is generated automatically.
After mapping the response from the AI, click on “Save and Send Test Request.” You should receive a positive response indicating that the message was sent successfully. Check your Discord channel to see the new message generated by Google AI.
This automation will run daily at 1:00 PM, generating and posting a new message in your Discord channel automatically, showcasing the power of Pabbly Connect in streamlining tasks.
In this tutorial, we explored how to use Pabbly Connect to integrate Discord with Google AI. By automating daily messages, you can enhance engagement in your Discord channel effortlessly. Try this integration today to experience the benefits!
